Re: Multiple outputs
Here is an example. The zip is just the subVIs.
This is the error code I get when tried to use the codes. Can you tell me what I did wrong?
1) Your Motor Output needs to be told which motor you are talking about.
2) You have not defined what to do with all the possible cases of joystick buttons. At the very least you need a "default" case to cover all uncovered bases. |
Can you send me some screen examples? I'm new and I can't visualize what you're telling me. Thank you.
Here's what you need:
1) Add a Motor reference (this motor needs to be opened in Begin.vi) 2) Put the cursor on the cases and right-click to choose "Add Case for Every Value" Then look for every new case that needs a motor value added to it. The output tunnel carrying the motor value will be solid when you have them all. It'll have a white center if you haven't fixed all the missing cases. Last edited by Mark McLeod : 26-01-2011 at 19:31. |
Thank you! Everything is working great now.
#7
As an aside, here is how I would select between multiple joystick or custom DS buttons.
#8
I would've broke both the motors up into two case structures and then have a boolean series hooked up to nested case structures.
