Go to Post ps... it is better to have built a robot and lost than to ever played basketball at all - Andy Baker [more]
  #31   Spotlight this post!
Unread 14-01-2011, 23:28
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
Re: Manipulators: Claws vs rollers?
We looked at a claw and a gripper, and made quick ptototypes of each. We are going forward with a claw, but not everyone has full confidence at this point.
A claw is a lot simpler and the parts that are exposed to damage (extended) are easier to fix or replace. It is lighter. A claw can't rotate a tube after picking it up, but this year most or all tubes will essentially be horizontal on the floor. We can do any necessary rotation with the arm. A claw can be made to pick up a tube that is in contact with the robot - and robot/tube contact should orient and locate the tube for pickup. A claw requires fewer wires running out to the tip of the maniplator. It is easier to modify the details of a claw (grip materials, length of the fingers, amount of clamping, etc. Hopefully, our claw will be done soon enough to build a roller claw if it doesn't work!
I expect the tubes to be inflated quite tight. Inflation pressure really changes the dynamics of the pickup. Whatever you use, be sure it can be adjusted for, or is relatively unaffected by tube pressure.
Finish early - then practice, break it, improve it, repeat.
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at St. Joseph and West MI in 2017)
FTC 6043 & 7911
  #32   Spotlight this post!
Unread 14-01-2011, 23:47
pfreivald's Avatar
AKA: Patrick Freivald
I was convinced with a claw when it was used to pick up a completely uninflated tube with incredible ease... While running.
No such thing as finishing early!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #33   Spotlight this post!
Unread 17-01-2011, 01:01
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
What are peoples thoughts on how fast they think the roller should run to adequitly pick up the tube?
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
  #34   Spotlight this post!
Unread 17-01-2011, 01:16
EagleEngineer's Avatar
EagleEngineer EagleEngineer is offline
AKA: Michael Amoun
FRC #1138 (Eagle Engineering)
EagleEngineer is an unknown quantity at this point
what would you use for a roller or collector that is legal in FRC? i know vex wheels are not legal. And im looking for a collector that is smaller that 4in in diameter? What would work
  #35   Spotlight this post!
Unread 17-01-2011, 01:19
pfreivald's Avatar
...as fast as it needs to...
No, really. Depending on the material surface, diameter, and geometry of your roller claw, that answer is going to have a lot of play.
Design, prototype, test, critique, redesign, re-prototype, test, critique, redesign, re-prototype, test, cry a little, critique... Repeat these steps as necessary!
Team 1551
I write books, too!
  #36   Spotlight this post!
Unread 17-01-2011, 01:20
pfreivald's Avatar
PVC with tape of some kind (grip tape or electrical tape)?
Pieces of pool tube?
...and why aren't VEX wheels legal for parts of the robot?
Team 1551
I write books, too!
  #37   Spotlight this post!
Unread 17-01-2011, 01:26
jblay's Avatar
AKA: Joe Blay
I find tank tread riveted to pvc pipe to be an easy solution. we've used it in the past and have never had an issue with not having enough grip on an object.
  #38   Spotlight this post!
Unread 17-01-2011, 07:26
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
There is no rule against using Vex wheels on the hostbot.
Drawer liner on a pvc pipe works well also.
  #39   Spotlight this post!
Unread 17-01-2011, 10:25
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
The little VEX wheels are almost ideal for a primitive roller claw. Thank goodness they're legal!
We had a very long discussion this weekend about pickup mechanisms. We listed a couple of observations as we acted out retrieval from the opposite side of the field:
  • Acquiring from the chute in the wall means the tube will most likely need to be reoriented at some point to prevent it from being inadvertently 'stolen' while crossing the field since it sticks out
  • Acquiring from the ground while in that lane is very difficult due to the wall that divides the lane and the opponent's scoring zone. This 12" wall makes it very difficult to accurately line up to a inflated tube that's only 9" high from ~50 feet away
  • It's very easy for opponents to 'snipe' a tube that's thrown outside of the lane just by blocking the path to the tube, then going for it (much like blocking out in Ultimate Frisbee)
  • It's very difficult to throw a tube in the lane to a place the drivers can see with much consistency
The thought came up that we need some sort of 'garbage chute' that the HP can dump the tube in and our mechanism can retrieve from. Yet we're running out of room and weight on the robot, heh.
So we're going to stick with a simple claw that only picks up from the ground, for the moment. We need to think some more. It was the first time we'd really considered roller claws; however they add an entire layer of complexity in control on top of an already somewhat complex control system (lift + wrist + simple claw will keep a driver very busy as-is).
GitHub
  #40   Spotlight this post!
Unread 17-01-2011, 10:36
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
On the subject of small wheels for Roller Claws and the like, may I suggest looking at the Bane Bots wheels? You can get them with a 3/8" keyed, 1/2" keyed, 1/2" hex, or 3/4" hex center bore, they're relatively cheap, and from our experience more than strong enough for small mechanisms such as a roller claw.
The only reason I would lean towards these over say, a vex wheel, is that they come in some smaller diameters and are much easier to drive than a vex wheel, unless of course you were to put some sort of hub onto the vex wheel.
http://banebots.com/c/WHB-WM
-Dustin Benedict
  #41   Spotlight this post!
Unread 17-01-2011, 11:12
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Another vote for BaneBots wheels. I've been using them for a (non-FIRST) robotics project, and they're great. They're lighter than the Vex wheels and have incredible grip. For the orange wheels (40 shore rubber), I measured a static coefficient of friction of 1.06 on a painted wood surface.
As thefro mentioned, you can attach them to just about any shaft with the help of the BaneBots hubs.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
  #42   Spotlight this post!
Unread 17-01-2011, 11:52
Chris is me's Avatar
AKA: Pinecone
Vex wheels work great on FRC robots - you just have to carefully modify them to accept a thicker axle. You won't be able to use them on a Vex bot again, but you'll have a unique, cool robot.
