Re: Legality of Jaguar closed-loop control modes
The key word is command, not data. |
A "bad" student could reprogram the Jaguars with entirely new firmware, but this would break several other rules. There would be no doubt that they were doing something illegal though, so I don't know why they bothered to mention it here. |
Since this "trusted heartbeat" is completely protected from interference - intentional or unintentional - from team software, it's this handshake between the protected FRC software on the cRIO and the FRC-specific firmware on the Jags that provides the required safety, allowing the driver station (or FMS when connected) to disable the Jag motor output, effectively negating any motor output "commands" that come from the team software on the cRIO or the internal control loops on the Jag. That's why the Jags require the special firmware when using CAN in order to be competition-legal. Quote:
To quote, adding my own emphasis: "There is no rule that prohibits the Jaguars from reading the values from the encoders, however note that Rule R49 requires that the ROBOT must be controlled by the cRIO." Here's a very plausible paraphrase (which is hopefully NOT what the GDC intends): "There is no rule that prohibits the Jaguars from reading the values from the encoders, however the Jaguars are only permitted to provide the values to the cRIO and all control calculations must be performed on the cRIO." Seems like we all agree it'd be non-sensical for the GDC to intend this - but it's unclear enough that we had visions of robots being wrongly declared illegal based on different inspectors' opinions. ![]() |
ok so if we interpret this the strictest way possible ( where the jag cant independently make a decision about its output ) wouldn't the current/voltage protection( a jag will shut itself off if it over amps or the voltage gets under 6v) built in to the Jags break this rule?
I dont think that this interpretation is correct ( or will remain correct ). |
The GDC has spoken, no closed loop control from the jaguar.
http://forums.usfirst.org/showthread.php?t=16326 Quote:
#7
It greatly complicates the cabling and increases the complexity of closed-loop control.Can someone ask on the First forum (it won't let me post) if this means that speed, current and position modes of the Jaguar are prohibited? If so, then there's no reason to use CAN bus. We might as well stay with PWM and the Victors. Heavy sigh... Last edited by taichichuan : 20-01-2011 at 23:56. |
#8
The only rule restriction is that commands must come from the cRio. The cRio can read the position (or speed) from the jaguar. PID (or other closed loop control) can be calculated on the cRio. Then the calculated voltage can be sent to the jaguar. Quote:
#9
The position (or speed) values can be read through the CAN bus (after the correct settings are loaded into the jaguar, SpeedReference for example). The voltage to send to the jaguar can then be calculated on the cRio. This does not use any of the Jaguar closed-loop modes, and so it seems legal. |
#11
But mostly this is a poor decision due to the reason Eric stated above. |
#12
ok so what about the attached limit switches on the JAGS. by default ( and I don't think there is a way of turning this off) in both the PWM and CAN mode you can attach 2 limit switched to the Jag to stop the motor at both its low and high points . . am I to understand that these ports are off limits as well?
I get the desire to minimize “unanticipated surprises”, but we have had these devices for 3 seasons, CAN for 2 ( I would like to know if any one used the closed loop modes last year),and a whole range of beta tests ( not to mention the inclusion of the closed loop modes in the custom FRC Labview and Jag firmware builds). it just seams a little weird |
#13
Personally I'm fine with that decision (strange as that decision may seem). It's one thing to use closed-loop control. It's another to implement it in your own code, especially if you're using PID control. I'd much rather have my team know how the stuff works, than just be able to hook it up and see it do its magic.
After all, that's pretty much what FIRST is all about. |
#14
a few years ago Dean talked about the idea that technology is something that is new to the generation. for his grandfathers generation the car was technology, for his generation the internet is technology, for this generation . . well we dont know. The point is each time we progress, the wild and amazing things of the past become base and mundane ( I would say transparent). When I was in high school ( circa 2004) it was all 15 pin analog ports and limit switches. if we wanted to do channel mixing that was like 2 weeks worth of coding, and trig for getting relitive positioning of the field, forget it!( I often wonder if those doing FIRST in 1994 would take a look at what I did in 2004 and say "well all the hard stuff is done for him what is he learning"). But now channel mixing and trig functions are mundane they are transparent, we talk about the underlying principals drop in the VI and move on. does this make the season any less hard? No work will always rise to its own level. This just pushes us to find something else thats new and interesting and exciting (technology). |
#15
The first programming language I learned was Z80 assembly, but I don't believe that I understood more when myopically concerned with register use than I do now when using WPIlib and can concentrate on higher-level design. |
