Go to Post Our coolant system consists of a freshman with a squirt bottle. - Holtzman [more]
Unread 17-01-2011, 00:41
Zachary Pilarsk Zachary Pilarsk is offline
FRC #1711 (Raptors)
Team Role: Electrical
Zachary Pilarsk is an unknown quantity at this point
Re: 3771 Chassis
its is a good design but you need to lose some weight and remove some parts of the frame
2009 T.C. Regional Image Design Winner
2009 Lansing Regional Image Design Winner
2010 T.C. Regional Image Deign Winner
2010 Grand Vally Regional Spirit Award Winner
2010 Michigan State Championship Image Design Winner
"Our robot might not work, we might not play the game well, but we sure do look good doing it."
Unread 17-01-2011, 00:46
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
Re: 3771 Chassis
As you build it, you can see how strong it is. The frame we have now kinda looks like your with all the top parts cut off. Its pretty stiff, i could jump in it with no worries. So we are not adding any more structure to it. When we add our arm, we will brace its structure to the frame to make the entire robot it more rigged. I think we are more concerned with the arm bending than the drivetrain.
Unread 17-01-2011, 01:38
pfreivald's Avatar
AKA: Patrick Freivald
Re: 3771 Chassis
Trim weight everywhere you can -- that looks like twice the chassis than is needed.
...and if you don't own a reliable, calibrated scale, buy one pronto. That way, as you modify and tweak from your original designs (which already have estimated weights, right?), you can re-weigh and re-estimate what final parts will be.
We've never been stuck having to drill lightening holes, but then, I'm awfully paranoid about it!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 17-01-2011, 01:45
SirTasty's Avatar
SirTasty SirTasty is offline
Middle Manager... :-(
AKA: Dolan Murvihill
FRC #2374 (CrusaderBots)
SirTasty is a splendid one to beholdSirTasty is a splendid one to beholdSirTasty is a splendid one to beholdSirTasty is a splendid one to beholdSirTasty is a splendid one to beholdSirTasty is a splendid one to behold
Re: 3771 Chassis
I'm not certain, but I suspect the much wider mecanum wheels might have trouble fitting in that housing. Also, your frame has a little bit too much unnecessary aluminum. It's important to be thinking about weight from kickoff day till robot inspection.
Best of luck!
Originally Posted by davidthefat View Post
Another note: sportsmanship and competition go hand and hand. In any sport, whether it is football or track and field. As the ball is snapped, you pound the guy across you and drive him until he is on his butt. After the whistle blows, you help him on his feet; repeat every down.
Homework? What's homework?
Unread 17-01-2011, 02:02
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: 3771 Chassis
How are you attaching the frame elements together? Welding? Gussets?
Unread 17-01-2011, 02:05
klbarie's Avatar
klbarie klbarie is offline
AKA: Kyle Barie
no team (HOT Team)
klbarie is an unknown quantity at this point
Re: 3771 Chassis
our welder is going to practice on some scrap to make sure he would be comfortable doing it, but if he is not, gussets
2009 - 2010: Team 67-The HOT Team-Student
2011: Team 3771-The Yooper Troopers-Mentor
2012: Team 4363-The Unbolted Puppeteers-Mentor
Unread 27-02-2011, 13:15
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Re: 3771 Chassis
A VERY important thing to remember about Mecanum wheels is that, UNLIKE standard wheels (or even Omniwheels!), for every forward or reverse pound of thrust you attempt to derive from a Mec Wheel, you ALSO get a pound of SIDE FORCE transmitted ALONG THE AXIS of the shaft, which MUST be transferred to the frame WITHOUT BINDING.
This is because the 45 degree rollers shafts "vector" the forces you apply equally to the side as well as forward & back..
To handle these extreme side forces, it means you need to add THRUST BEARINGS on both ends of each shaft. This insures the wheels "push" on the chassis and do not "bind" TO the chassis from friction whenever you drive them. (IOW, adding TBs GREATLY increase efficiency.)
We've had very good luck with VXB Bearings, for our Mecanum Drive thrust bearings:
... www.vxb.com
Search for "Thrust", and find some that fit your shafts. (They ship same day, too... )
BTW... If anyone has other bearing sources they like, please also post them here! Thanks!
Thrust Bearings come as what looks like a triple pair stack... A pair of flat or grooved "washers", sandwiching a ring containing a circular set of either ball bearings or radially mounted needle bearings. Buy enough sets in your shaft size for each end of every wheel shaft (plus some spares...).
Simply add one tri-stack to each side of each wheel. Make sure if the "washers" are grooved that the grooves face the bearing ring.
(Personally I prefer stacking them immediately on either side of the wheel itself vs between the spacer and the frame, because this also eliminates all "spacer spin drag" on your shafts as well.)
...Easy Breezy...
BTW, TBs help with NON-mecanum drives too, by (a) removing your side force wheel-to-chassis friction whenever someone pushes you sideways! (At those times, every little advantage to help you escape is appreciated... ), and (b) to keep wheels from binding because someone went crazy in the pit tightening the shaft bolt down too much and the spacers pinched the wheel.
Note that you STILL need REGULAR bearings too, for allowing the wheel and sprocket assembly to spin on the shaft! The Thrust Bearings just "surround" your wheel-&-sprocket assemblies, to help them transmit the SIDE forces to the frame without binding the wheel.
If you forgot about them during initial assembly, no sweat. They're easy to add later in the pit when they come in simply by trimming the right amount of shaft spacer length and stacking them in around each Mecanum Wheel.
One OTHER thing... With Mecanum Drives, you also need to make sure all four wheels are on the ground at ALL times, or it gets wonky... With a flat field like this year's game (no "ramps"), "frame flex" is normally sufficient to eliminate the need for suspending a pair of wheels on a pivoting subframe,
BUT, if you make your frame TOO STIFF, you MAY encounter a touch of drive vectoring problems should one wheel lift up too much and loose traction. Watch for that.
IF it becomes a SERIOUS problem, there are methods to later add just a "wee bit" of spring action to one end's pair of wheels to cure it. The symptom to watch for will be the bot spinning or vectoring in directions you didn't intend it to go, especially with strong moves that tilt the bot slightly, removing pressure from at least one wheel.
Just let me know if this happens to you, and I can point you toward some solutions for it.
Good luck! I hope this helps...
- Keith
(Who also happens to be a List Dad for an Omni and Mecanum Drive elist...)
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Unread 27-02-2011, 16:27
David Dawson's Avatar
David Dawson David Dawson is offline
Capt'n turned Mentor
FRC #3771 (Yooper Troopers)
David Dawson will become famous soon enoughDavid Dawson will become famous soon enough
Re: 3771 Chassis
I guess I should post the finished product in this thread. The robot ended up with a finished weight of ~90 pounds. Overall I think we will field an excellent rookie bot this year.
Unread 27-02-2011, 16:33
Chris is me's Avatar
AKA: Pinecone
Re: 3771 Chassis
I've never heard of a team doing this... Is this true? Why can teams "get away" without thrust bearings?
Unread 27-02-2011, 16:42
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
Re: 3771 Chassis
Personally I love this type of frame (though I may be biased ). It looks very similar to my team's frame.
http://www.chiefdelphi.com/media/photos/36277
I don't know if you said it already, what is the wall thickness on the tube you are using. My team always uses 1/16" wall thickness and never has any problems with strength, I will however just say that we do have a professional welder do our frame so that may help. but besides I like it, and if you are using 1/16" thickness it should be incredibly light.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
Unread 27-02-2011, 16:58
Re: 3771 Chassis
I'm not certain but i believe its 1/8 inch aluminum but its still light due to welding vs bolts. this year we tried to keep it as simple as possible.
Unread 27-02-2011, 17:05
Garret's Avatar
AKA: Garret Smalley
Re: 3771 Chassis
1/8 in will be very strong and still relatively light. We use 1/16" just because its lighter and gives us some flexibility when it comes to weight and room to "overbuild" the frame. Good luck and your robot looks really good.
7 Years of FRC
Unread 27-02-2011, 17:22
Re: 3771 Chassis
Did you weld your frame with the 1/16"?
Unread 27-02-2011, 17:31
Garret's Avatar
AKA: Garret Smalley
Re: 3771 Chassis
Yes, we have been lucky enough (despite in prior years building out of a garage) to always have a welding sponsor. We have never had problems with the 1/16" material being welded as far as I know.
7 Years of FRC
Unread 27-02-2011, 19:06
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: 3771 Chassis
We use T-Slot for our lower frame, and 1/16 for the upper.
