Go to Post ...It's two years old, but GP is GP. - Brandon Martus [more]
Unread 17-01-2011, 03:35
John G John G is offline
FRC #0399 (Eagle Robotics)
John G is on a distinguished road
Labview install troubles (not like other posts)
From the posts I have seen from searching, other people have been having trouble installing some of the products but are still able to download about four of the products. I am running Windows XP, and get an
"error code 32. nidist.id file not found" when trying to install the CD. It gives me an option to install the other products, so I click "ok" to skip the first one, but then this happens over and over again so none of the products are actually installed.
Any help?
Unread 17-01-2011, 09:37
MSI_Guy MSI_Guy is offline
MSI_Guy is an unknown quantity at this point
Re: Labview install troubles (not like other posts)
Hi John G,
Which set of software were you installing, and were you using the DVD distributed by FIRST? The only reason that this error should appear is if the nidist.id files were actually missing from your distributions. This could possibly happen if you downloaded the files from your network and your firewall blocked some of the files from downloading, or if you are installing on a machine without a DVD drive and you didn't copy the entire contents of the FRC DVD.
Unread 18-01-2011, 19:20
Carter12s's Avatar
Carter12s Carter12s is offline
Team Cap
FRC #3374 (Robo-Broncs)
Carter12s is just really niceCarter12s is just really niceCarter12s is just really niceCarter12s is just really nice
I experienced this same problem on a laptop that I was trying to install Labview on. The same disk I used in the Laptop was able to install Labview on other computers. I gave up and was not able to fix the problem. So I don't really have any good advice, but you are not the only one who had this happen.
Programing is the real way to build a robot.
