Go to Post “Coming together is a beginning; keeping together is progress; working together is success.” - Henry Ford - hiyou102 [more]
Unread 01-15-2011, 02:52 PM
colinchocolate colinchocolate is offline
Java Programmer
AKA: Colin Hood
FRC #1559 (Devil Tech)
colinchocolate is an unknown quantity at this point
axis 206 camera problems
We've worked with the camera for several days. After our second day, the camera suddenly stopped working through the dash. We checked to make sure that the camera works directly through the computer on its server. The IP's are correct, it has power, and we have code that is using the camera. It keeps double blinking once after a reboot. Any ideas?
Unread 01-17-2011, 08:36 AM
Re: axis 206 camera problems
I'm not sure what "double blinking" looks like. You may need to be more specific about what LEDs are doing what. With nothing else to go on, the 206 has the reset button that is prone to being mashed when the camera is mounted on the robot. Verify that the button is not pressed, or unmount the camera to see if the problem goes away.
Greg McKaskle
