Go to Post I wanted to make an epoxy/carbon fiber/fiberglass arm for our 'bot, but I was outvoted by conservative teenagers. Oh well... - Rick TYler [more]
Unread 17-01-2011, 08:48
Re: DAP-1522
Originally Posted by Joe Ross View Post
To bad ...
So much for remotely coordinated bug fixes in code and docs.
Since most DSes will only be used for one team, it shouldn't matter much once the profile on the DS is updated.
Greg McKaskle
Unread 17-01-2011, 09:19
Re: DAP-1522
As a note, for competition you must set the DAP into the bridge mode.
As a special highlight, you may now tether through the DAP when it is connected. No more disconnecting the radio from the Crio to program and then forgetting to plug it back in on the field. I saw a demonstration (over the weekend) of the new setup tool teams will be using to set WPA encryption at events. It is very good and simple to use. Teams will need to bring their DAP to the setup kiosk (laptop) at each event to set the key. On screen instructions are provided during setup to help you walk right through it.
Unread 17-01-2011, 11:10
Re: DAP-1522
Wait, what?
Are you saying that we will be permitted to leave the DAP powered up when running the robot in the pit?
Unread 17-01-2011, 11:39
Re: DAP-1522
The decision on that is still being evaluated, please standby for official declaration on wireless use in the pits at events.
