Go to Post please remember that the children we are trying to positively influence do read these forums. - Amanda Morrison [more]
Unread 17-01-2011, 09:52
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Connection problem
From my experiences with networks over the years, it makes sense to me that you'd want to do something like loading code with a wired network. And you usually want to operate the robot with the wireless network.
But I'm weird.
Unread 17-01-2011, 10:05
whcirobotics's Avatar
whcirobotics whcirobotics is offline
FRC #1514 (Vikings)
whcirobotics is an unknown quantity at this point
@Mark
It is the direct code that comes with the default framework in Labview, so i doubt it is the same problem as before, but i will do the usuage thing and check after school at 3:05 and reply back
@squirrel
It makes sense to do it wired but the wire goes only so long. Althought both are good, wired or wireless, i cannot deploy the code using either way. :S
"A team back in training !"
Unread 17-01-2011, 10:37
Check the CPU usage first so you know what's happening there.
I assume that after you reimaged the cRIO with the 2011 v25 that you didn't download any robot code?
So there shouldn't be anything running on the cRIO and the CPU usage should be close to the bottom.
Does the timeout message stay up for a long time? It's normal to see it occasionally and it'll usually go away within 20 seconds or so.
Here is something else to try after school for the timeout error you're seeing:
  • Flip the NO-APP DIP switch on the cRIO and reboot it (reset button or cycle the power), then turn the NO-APP switch off again.
  • Then try the Run button.
