Go to Post When a team is composed completely of robot builders and technical people that team cannot exist just like a company cannot exist if it is only made up of engineers. - Garret [more]
Thread Tools Rating: Thread Rating: 4 votes, 4.50 average. Display Modes
  #61   Spotlight this post!
Unread 17-01-2011, 06:49
tagayoff's Avatar
tagayoff tagayoff is offline
FRC #3512
tagayoff is a jewel in the roughtagayoff is a jewel in the roughtagayoff is a jewel in the roughtagayoff is a jewel in the rough
Re: Minibot climb rate
A house "4 way" switch will reverse the motors...
  #62   Spotlight this post!
Unread 17-01-2011, 10:40
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
*blinks*
I hadn't even heard of four way switches. That's even better!
  #63   Spotlight this post!
Unread 17-01-2011, 21:41
tagayoff's Avatar
FRC #3512
Smile Re: Minibot climb rate
4 way switches are use in rooms where lights are controlled from more than two places at once. The first two locations use 3 way's and the 3rd "or more" use 4 way's. The switch has 4 terminals on it . In one position it connects across. In the other position in cross the terminals. Great for reversing DC motors.
  #64   Spotlight this post!
Unread 17-01-2011, 21:55
Duke461's Avatar
Duke461 Duke461 is offline
Boiler Strong.
AKA: Ben Carson
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
Our minibot got to the top of the pole today in 4 seconds. I'd love to share the video, but its "Top secret Confidential" stuff right now
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
  #65   Spotlight this post!
Unread 17-01-2011, 22:10
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Food for thought...4 way switches will indeed help you reverse your motors but there is a cost. Even stripped down they are relatively heavy and also one must consider the rate of the descent and the endpoint velocity as your bot strikes the base platform. Not sure what the effect on the field element will be. Has anyone tested a motor aided return to the base platform?
  #66   Spotlight this post!
Unread 18-01-2011, 09:25
obsidianjeff's Avatar
obsidianjeff obsidianjeff is offline
former member, current mentor
AKA: Jeff
FRC #2450 (The Raiderbots)
obsidianjeff is an unknown quantity at this point
wouldn't a simple resistor on the switch be enough to make it drive slower in one direction but not effect the upwards movement?
"The tragedy of science: the slaying of a beautiful hypothesis by an ugly fact" - Thomas Huxley
  #67   Spotlight this post!
Unread 18-01-2011, 09:36
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
If resistors & diodes were allowed, perhaps when combined with a diode this would work fine.
GitHub
  #68   Spotlight this post!
Unread 18-01-2011, 09:51
AKA: Jeff
gah! of course in my haste to develop a simple easy solution i forget to check the list of acceptable parts...
  #69   Spotlight this post!
Unread 18-01-2011, 16:19
vamfun vamfun is offline
Mentor :Contol System Engineer
AKA: Chris
FRC #0599 (Robodox)
vamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of light
Send a message via AIM to vamfun
If you are intent on driving it down, you can switch the motors to be in series and this will at least cut the voltage in half for each motor which effectively cuts the power by 1/4 th.
But I can't imagine that the drag torque of these motors when properly geared for speed will be enough to hold the bot up the pole with no power. I don't have a number for the FTC motors but the vex 393 motors have about 1 inlb of drag torque or about 7 % of the Max torque. If the FTC are about the same % then you would only get about 21 oz in of drag per motor or a total of 42 oz in (2.6 inlb) for two motors. . The load torque for a 4 lb minibot would be 4*radius*gear_ratio which for a typical mini bot is 4*2*2 = 8 inlb. So I think the minibot should come down by its self with my assumptions.
  #70   Spotlight this post!
Unread 18-01-2011, 22:32
tagayoff's Avatar
FRC #3512
I was thinking,
On->forward...contact->up... contact->off...gravity-> down.
on/off .12 lb 4 way .18 lb
  #71   Spotlight this post!
Unread 19-01-2011, 00:26
jnapp18 jnapp18 is offline
FRC #3173
jnapp18 is an unknown quantity at this point
4.5 second climb on first proto... time to lose some weight...
  #72   Spotlight this post!
Unread 19-01-2011, 12:48
Perhaps it would also be useful to monitor wheel encoders as well. If the wheels travel 12 ft climbing a 10 ft pole, your problem isn't weight. Viewing the velocity and other derived values per wheel would be pretty interesting to evaluate different prototypes.
Greg McKaskle
  #73   Spotlight this post!
Unread 19-01-2011, 12:58
perry3018 perry3018 is offline
FRC #1543
perry3018 is an unknown quantity at this point
are you allowed to use the surgical tubing on the mini bot????
  #74   Spotlight this post!
Unread 19-01-2011, 13:09
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Greg McKaskle
You are absolutly correct that this information would be very usefull. The problem is, if you added the encoders and an NXT to capture that information, you would be radically changing the characteristics of the minibot. The data would not be relative to the actual performance of the bot in it's final configuration.
  #75   Spotlight this post!
Unread 19-01-2011, 13:12
tagayoff's Avatar
FRC #3512
<R92> The following items are the only permitted materials for use on the MINIBOTS:
U. Rubber bands,
V. Surgical tubing,
