Re: WindRiver IO Error - Please Help!
I'll try but, unfortunately, there isn't much more to tell. I can setup the team network and everything connects as it should (router, driver station, cRIO...etc). I can even connect to the network using WindRiver on my laptop. I just can't download new code to the cRIO.
I'm sure you know that when you want to download new code in WindRiver you select the FIRST drop-down menu at the top of the screen and select "Deploy." When I do that I get an error message screen that says "IO Error while downloading program to robot." Everything else seems works just fine. I was able to use the "Undeploy" selection so now the cRIO has no code and I can't download anything. If I can't solve this then I'm afraid I'm going to have to completely uninstall and then reinstall WR to see if that helps, but I really don't want to have to do that. Thanks for looking at this post. Eric |
I'm not sure. I haven't changed anything from last years settings and it was working fine. Could you please elaborate? Thanks.
Eric |
I've figured it out. I guess you can't rename the project in WindRiver without it affecting the .out file. Thanks for your help!
