Go to Post Consider yourself mentored, you have learned a lesson: "Don't stick your hands in icky things." - Amanda Morrison [more]
Unread 17-01-2011, 11:38
3p1c w1n 3p1c w1n is offline
FRC #1529
3p1c w1n is an unknown quantity at this point
Re: Led Tape Control
Originally Posted by Foster View Post
As far as the Spike vi goes, the one for the compressor is good. It wants the robot to be enabled and then uses the value from the pressure sensor to turn the spike on and off. You would feed inputs into the vi as if you were the pressure sensor.
Thanks! I didn't think about feeding inputs to it.
~Team 1529 Cybercards~
Unread 17-01-2011, 12:03
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
There is a VI to set a relay. It is much better than trying to use the Compressor VI to set the relay. The compressor VI (in LabVIEW) creates a new thread, constantly getting the pressure switch and writing the relay. Under the WPI Robotics Library palette, go to Actuators->Relay and use the Relay Open and Relay Set VI's.
Kettering Motorsports
Unread 18-01-2011, 08:14
The Spike relay is not rated for rapid ON/OFF operation if you are intending to make flashy lights. If the LED device you are using requires a simple ON/OFF power connection, and it draws less that 20 amps, the Spike is a perfect fit.
