Go to Post There are no simple solutions, as every solution has its own problems. - M. Lillis [more]
Unread 17-01-2011, 11:39
kgcarini kgcarini is offline
FRC #3307
kgcarini is an unknown quantity at this point
LabView Problem
When I install the LabView 8.6.1 for FRC 2011 and FRC 2011 Tools and CompactRIO Drivers it seems to install fine; however, when I open up Labview it is not the FRC edition and does not have the robotics library. I did use the DVD that came with the kit. I did use the serial number it came with. Please help. Thanks.
Unread 17-01-2011, 11:53
Re: LabView Problem
You then need to install a series of Software Updates to get the FRC specific stuff.
Unread 17-01-2011, 11:54
Re: LabView Problem
After installing the software from the DVD, you must install the updates.
This is described in the Getting started with the 2011 control system document from the Kit of Parts website.
Unread 17-01-2011, 12:23
FRC #3307
Re: LabView Problem
Thanks for your help!
