Go to Post Blowing out the transmission on your mini-van while hauling a trailer 700 miles from home is not fun. Trust me on this. - dlavery [more]
Unread 17-01-2011, 14:49
EOC's Avatar
EOC EOC is offline
AKA: Eric Curry
None #1208 (Metool Brigade)
EOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant futureEOC has a brilliant future
1208 after week one.
http://www.youtube.com/watch?v=YBlqO...layer_embedded
Unread 17-01-2011, 15:03
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Re: 1208 after week one.
How will it sit within the starting perameters with a claw/grabber attached to it?
Good choice of music.
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 17-01-2011, 15:17
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Excellent progress! This is a great first iteration.
The next step is to attach a front/rear bumper and pick up a game piece with it. You may find that Bryan's concern is very valid from both a legality perspective and tube acquisition perspective.
If you gear down that arm a bit more, you will have more control as it comes down (preventing it from slamming). It looked like 2 window motors powered the rotary joint? In that case, you might need to add another sprocket stage.
GitHub
Unread 17-01-2011, 23:50
Sandvich's Avatar
Sandvich Sandvich is offline
NOM NOM NOM
AKA: Kyle
FRC #0696 (The Circuit Breakers)
Sandvich is on a distinguished road
B-but... you did that in one week?
And the chains for the wheels look kinda loose... you should probably add pillow blocks or something else to increase the tension.
Unread 18-01-2011, 00:07
NorviewsVeteran's Avatar
NorviewsVeteran NorviewsVeteran is offline
Precision Driver Extraordinaire
AKA: Richard Raitt
FRC #1793 (Pilots)
NorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond repute
It looks like most of the weight is on the back, resting on the omni wheels instead of the traction wheels. I suggest swapping them so the traction wheels have more weight on them, making turning easier and smoother. Doing that worked wonders for us in 2008.
Also, WOW! That was fast!
______
I was in Scouts but I wanted out by the third meeting. I was in TSA, but I quit after a couple of weeks. I don't go camping with the SCA anymore. I was in taekwondo but I had to leave because I got sick.
I joined FIRST and stuck with it. It was nice enough to return the favor.
Unread 18-01-2011, 07:13
EOC's Avatar
EOC EOC is offline
AKA: Eric Curry
Thanks for all the feedback. We have noticed all the items mentioned; give us another week, they will be remedied.
Unread 18-01-2011, 09:21
tbmantia's Avatar
tbmantia tbmantia is offline
FRC #1288 (RAVEN Robotics)
tbmantia is an unknown quantity at this point
Send a message via MSN to tbmantia
what motors are you using to move the arm up and down? 2 window motors?
Unread 18-01-2011, 11:07
EOC's Avatar
EOC EOC is offline
AKA: Eric Curry
Yes, two window motors.
Unread 18-01-2011, 11:50
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
What do you mean, claw/grabber?
Kidding. We designed the Arm specifically to be longer than it was needed, so we can get the optimum height out of it, we plan on cutting off at least around 6" to fit our grabber. The reason it is banging up and down is there is extra weight on the arm that is mimicking the worst case weight of our grabber, the real one will not weigh as much and it is much more controllable.
Most of the weight will normally be towards the front of the robot, as that is where our arm/grabber is. In the end we are shooting for dead center for weight distribution.
