Go to Post The proper way to advance forward is by bringing the bottom up, not by limiting how high the top can fly. - artdutra04 [more]
Unread 17-01-2011, 15:29
mariak37 mariak37 is offline
FRC #0935 (RaileRobotics)
mariak37 is an unknown quantity at this point
CAN Problem
We've been trying to test the CAN Black Jaguars and used the attached program. However, when we run the program, nothing happens. The lights continue flashing at the same speed that they were, no motors move, nothing. Is there something I need to fix? I feel like I might be identifying something wrong (CAN isn't quite as idiot-proof as PWMs)...
We have updated the firmware to version 92, Black Jaguar, and have assigned the IDs of the Jaguars. Please help!
Thanks!
Maria
Unread 17-01-2011, 21:26
Re: CAN Problem
Did you remember to enable the robot?
Unread 18-01-2011, 13:21
dsmith14469 dsmith14469 is offline
FRC #1511
dsmith14469 is an unknown quantity at this point
Re: CAN Problem
Have you tried the CAN program to test out the Jaguars first to make sure they were programmed properly. Do you have the terminator in the last Jaguar?
