Go to Post words of advice: never tease your dad about his receding hair line. it will come back to haunt you. trust me. - Brandon Martus [more]
Unread 17-01-2011, 14:16
mattiej's Avatar
mattiej mattiej is offline
Programmer Guy
FRC #3413 (Mad Cows)
mattiej is an unknown quantity at this point
Holonomic Code Problems
After searching through all the old threads, I was still unable to find the solution to my problem.
My team has decided to use holonomic for this drive system. I found the default way to program it, and by looking through other threads how to connect it (I use LabVIEW). But whenever I run it, the wheels automatically start turning. My code looks something like this:
http://www.chiefdelphi.com/forums/at...9&d=1287950414
Help?
Man pretending to be interested: "So how does this robot of yours work?"
Me tired of man pretending to be interested: "Magic. And Purple Yetis."
Unread 17-01-2011, 15:09
Racer26 Racer26 is offline
Re: Holonomic Code Problems
You haven't told us anything about the setup on your robot. Please describe what wheels you have on your robot, how they're connected to some motors, and how the motors are connected to the control system. There's literally thousands of places that a mistake could have been made, and additionally, the term "Holonomic" is less-than-fully understood by the community as a whole, and different people will often take it to mean different things.
Unread 17-01-2011, 15:12
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Just to clarify, by holomic, do you mean omniwheels, or mecanum?
Unread 17-01-2011, 15:23
It can be due to a mis-calibrated joystick.
You can check your joystick on the PC by going to Control Panel -> Game Controllers to see what it thinks the joystick is doing.
It could be due to mis-calibrated speed controllers (less likely). You can test this by temporarily changing your code to use "0" constants to feed your Holonomic Drive function. (This will also tell you if it's your joystick input.)
If your wheels are still turning with constant zero's in place, then it's probably a wiring issue.
Unread 17-01-2011, 15:43
3p1c w1n 3p1c w1n is offline
FRC #1529
3p1c w1n is an unknown quantity at this point
That code is for use with a joystick that can rotate. The axis3, using a standard joystick, would be for the throttle control on the joystick. if you are using a non-rotating joystick and the throttle is not exactly centered, then the wheels would move.
~Team 1529 Cybercards~
Unread 17-01-2011, 15:49
FRC #1529
you could also assign the rotation to a 2nd joystick like we're using in our code as of now, since we're using standard joysticks.
Uploaded with ImageShack.us
Unread 17-01-2011, 16:18
mattiej's Avatar
Programmer Guy
[quote=1075guy;1002078]You haven't told us anything about the setup on your robot. [quote]
Sorry about that. Forgot to. Here is a picture of my setup:
Mecanum
This will be the next thing I will try to check. It's possible, but I tried adjusting the joysticks. Just as a question, what should I change if that is the problem?
Sorry I wasn't excatly clear. I meant to say that I had changed it from that pic, and hooked it up like 3p1c w1n has. I put the second joystick's x axis to control the rotation.
Unread 17-01-2011, 16:52
Jogo Jogo is offline
FRC #0353 (Pobots)
Jogo is on a distinguished road
From the picture, it looks like the wheels are mounted wrong...the top view should look like an "X" and not an "O".
Unread 17-01-2011, 16:57
Yup. You need to swap the left&right or front&rear wheels
Unread 17-01-2011, 17:06
mattiej's Avatar
Programmer Guy
When I looked up documentation on it, it said it can either look like a X or a diamond. But the problem is not the orientation of the wheels ( I will deal with that when it comes ). The problem is that it keeps on running even with the joystick not being moved.
Unread 17-01-2011, 17:14
FRC #1529
have you tried running the code without the joysticks plugged in?
Unread 17-01-2011, 17:28
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
If you run the code by pressing the run arrow rather than through a build/deploy, you can also click on the wires to probe what the values coming out of the joysticks are in real time. I'd recommend that as a debug measure.
Unread 17-01-2011, 18:16
Yes it can look like either an X or a diamond: it should look like an X when viewed from above, and a diamond when viewed from below.
Yours looks like a diamond when viewed from above.
Would you please post a link to the above-mentioned documentation. I would like to read it and maybe contact the author.
Thanks.
Unread 31-01-2011, 22:32
chs938 chs938 is offline
FRC #0938
chs938 is an unknown quantity at this point
Check your USB hub and joysticks. We had a condition where you would enable the robot and it would start creeping on it's own. It was a new condition that occurred without new code or changes to the drive chassis. Ultimately we swapped out the hub and were back up and running.
