Go to Post Great people like you both [Scott and Libby Ritchie] make the FIRST community even better! - tiffany34990 [more]
Unread 17-01-2011, 17:01
rahilm's Avatar
rahilm rahilm is online now
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
Re: RS775 Gearboxes
Originally Posted by Chris is me View Post
It's far too fast to be easy to control, in my opinion. Most arms have about 90-100 degrees of travel. I"m thinking 45 degrees per second is much more reasonable.
With some degree of automation (PID, specifically) and the proper control systems, you could go with a much faster speed without losing much control.
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
Unread 17-01-2011, 17:10
Best Available Data
FRC #1778 (Chill Out!)
Re: RS775 Gearboxes
Because I trust software about as far as I can throw it, and since it has almost no mass, I can't throw it very far.
I know there are a lot of great programmers in FIRST. I also know that teams are always pushed right up to a deadline, and the software teams get very little time to test. I also know a slow arm is a lot easier to stop, and if your arm is going 180 degrees/second and you miss a limit switch for some reason, something is going to break. There are a lot of great teams in 2007 that didn't actuate at anything close to 180 degrees/second. There probably are some that did too, but I'm a lot more comfortable with a slow arm that I can fall back on a human to control, than needing a relatively complex piece of software to control.
Why would you use an encoder? It is simpler to use a potentiometer since your are limited to probably less than one revolution, no?
Unread 17-01-2011, 17:17
pfreivald's Avatar
AKA: Patrick Freivald
Re: RS775 Gearboxes
A. Trimpots drift. Encoders don't.
B. The same idea could be replaced with "why do this in the age of the limit switch?" and the objection is the same (though with slightly different hardware and software, without quite so much elegance).
C. With 20 minutes of LabView training, I was able to bring an arm up to whatever height I wanted to by pushing the appropriate button.
D. If you haven't made things autonomous, then you can't score in autonomous...
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 17-01-2011, 17:43
Jason Law's Avatar
Jason Law Jason Law is offline
Team Captain
FRC #2834 (Bionic Barons)
Jason Law is just really niceJason Law is just really niceJason Law is just really niceJason Law is just really niceJason Law is just really nice
Re: RS775 Gearboxes
Banebot just emailed me back:
Hello,
The new CIM-U-LATOR gearbox and P60 mount for the RS775s will be available for order Wednesday.
Thank you,
BaneBots Sales
Jason Law
Unread 17-01-2011, 20:29
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: RS775 Gearboxes
On the BaneBots page, it says they'll be offering a 64:1 and a 256:1 for the 775. Really? Nothing in between those ratios?
Unread 18-01-2011, 09:36
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: RS775 Gearboxes
I would imagine that they may be the only packages for the RS775 that they offer off the shelf, but in years past swapping motors between BB transmissions was just a matter of ensuring you have the correct Mounting Block for the Motor and series of Transmission - so you should be able to buy a P60 with the desired ratio and swap the mount, right?
-Dustin Benedict
Unread 18-01-2011, 10:49
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: RS775 Gearboxes
Actually, on the planetary page for the P-60 for the RS-775, it says they have multiples of 4.
4:1, 16:1, 64:1, and 256:1.
Unread 18-01-2011, 12:11
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: RS775 Gearboxes
What Tom said. Looks like they're initially only offering the 4:1 stages for the RS-775s. If the RS775 4:1 stages are identical to the RS-540 4:1 stages, then you could buy some of the 5:1 stages from the P60 Gearbox Parts pages and swap them in to make up your own ratios. I suspect they're not going to have a 5:1 pinion for the motor itself, so you'd be swapping in at the 2nd stage or later, which is a little less than ideal... But you'd still get the different ratios you're looking for. 4:5:4 = 81:1, 4:5:5 = 103:1, which gives you a few more options between 64 and 256. Granted that you still have the big jump up from 103 to 256, but unless BB comes out with some 3:1 stages, that's always gonna be a sizable jump.
Unread 18-01-2011, 14:12
Alienvin's Avatar
Alienvin Alienvin is offline
Technically Speaking, Who Knows....
AKA: Vinny
FRC #1546 (Chaos Inc.)
Alienvin is an unknown quantity at this point
Re: RS775 Gearboxes
RS775 18V Motors...... Before jumping to the motor with the larger number, check out the Motor Specs to each of the available Motors. In my eyes, that RS550 Motor in most ways is superior and now one of our fellow FIRST Team members spoke to Banebots this morning about the Availability of the different versions of the gearboxes for the RS775 Motor..... More options going with the lower motor. Plus more Torque.
2010 Regional Finalist Award Winner - SBPLI Long Island Regional
2007 Kleiner Perkins Caufield & Byers Entrepreneurship Award Winner - SBPLI Long Island Regional
2006 Johnson & Johnson Sportsmanship Award Winner - SBPLI Long Island Regional
2005 Rookie All-Star Team Award Winner - SBPLI Long Island Regional
http://teacher.baldwinschools.org/robotics
Unread 18-01-2011, 14:34
Aren Siekmeier's Avatar
on walkabout
Re: RS775 Gearboxes
Can you explain what you mean by this? From the specs I have, it looks like the RS 550 outputs 21 fewer Watts at peak power (266W vs. 245W). To me, this is strictly inferior (although not by much). Is there some other factor you are taking into account? I have also heard that because the motor is designed for 18V, it runs more reliably at 12.
We are considering using one RS 775 for each of the strafing wheels in our holonomic drivetrain. Will the load from a drivetrain be too much for these motors and the gearboxes on them? There seems to be some concern about max output torque. Would the RS 550 be a comparable alternative, in light of the greater availability of those gearboxes?
Unread 18-01-2011, 14:35
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Re: RS775 Gearboxes
Plus more likely to catch fire under stall load!
I'll stick to the 775's and their greater robustness...
Unread 18-01-2011, 14:46
Re: RS775 Gearboxes
Seconded! RS-550's and FP's fail spectacularly under heavy loads. For the uninitiated, these motors have nice little plastic impeller fans to blow air across the coils and cool them. But the more you load them, the slower they turn, the hotter they get... This continues for a short while till you melt the little plastic fan. At that point, the motor's toast because it'll never be able to adequately cool itself. And that's assuming it hasn't managed to catch fire or short itself out before the breaker trips.
Unread 18-01-2011, 14:42
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Re: RS775 Gearboxes
Which specs are you looking at when comparing those two motors? I see two conflicting sets of numbers when I look at the motor curves on the KOP website and then compare to the yellow BaneBots Motors page from the kit. The motor curves give lower numbers than the BaneBots sheet. Here is what that sheet lists for RS-775:
No Load: 13000 RPM, 1.8 A
Peak Efficiency: 119 W, 11360 RPM, 12.5 A, 14.2 oz-in.
Stall: 86.7 A, 110.8 oz-in.
Then you go to the site listed on the yellow sheet, www.banebots.com/M7-RS775-18, and you find a third set of numbers.
Does anybody know which numbers are right? The motor curve on FIRST seems wrong.
on walkabout
Re: RS775 Gearboxes
I am using the numbers from the Banebots site for the 18V motor, then bringing them down according to the Voltage difference, giving the performance at 12V.
These are:
Free Speed - 13000 rpm
Stall Torque - .7833 Nm
Stall Current - 86.67 A
Free Current - 1.8 A
for the 18V RS 775 running at 12V.
Unread 18-01-2011, 14:47
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Re: RS775 Gearboxes
There was another thread about this, and banebots posted some official numbers for all the KOP motors, including the 775-18 running at 12V.
P60 with RS775, P80 with RS775 and CIM-U-LATOR should be up on the web site by the end of the week and available for order at the start of next week.
Links to data sheets for the BaneBots motors found in the KOP:
http://banebots.com/docs/M7-RS775-18-AT12V.pdf
http://banebots.com/docs/M5-RS550-12.pdf
http://banebots.com/docs/M5-RS540-12.pdf
http://banebots.com/docs/M3-RS395-12.pdf
Note the RS775 data sheet is for the 18V motor in the KOP at 12V
BaneBots
