Go to Post I am specifically looking for Rhode Island, Hawaii, New Hampshire, Nevada, California, Florida, ... oh heck, all of the rest. - Rosiebotboss [more]
Unread 17-01-2011, 12:26
KevinSears KevinSears is offline
KevinSears is an unknown quantity at this point
Line Sensor Height
Anyone know how high we should put the line sensor away from the ground?
Unread 17-01-2011, 12:29
Re: Line Sensor Height
Sorry to answer this way, but high enough to be effective and low enough to be accurate. Your mileage may vary...
FLL has been using line following forever. Some of them are good, some are bad, sometimes ambient lighting interferes.
Unread 17-01-2011, 13:01
DarrinMunter's Avatar
DarrinMunter DarrinMunter is offline
Fixes parts that leak smoke
AKA: Darrin Munter
DarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to behold
Ambient light should not be a problem with these because there infared and have a small beam spread at a close range. - These are nothing like the Lego light sensors - those will detect any type of light. These Allen-Bradley units are industrail photo-eyes and are made to be used in a factory environment, and are unaffected by normal lighting.
Also each photo eye has a range adjustment on the top. For what were using them for you many want to have them turned all the way down.
The data sheet that came with these has a lot of good information in the graph tables about the beam spread and distance.
We are now testing our's with our Lunacy bot, we just made a flat plate with the sensor mounted to it and then attached the plate to the bot's trailer hitch.
Unread 17-01-2011, 13:17
Darrin,
I mention it as the studio type lighting used in many regionals has a fair amount of Infrared output.
Unread 17-01-2011, 13:39
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
slightly different question: How far apart should the be? We are going to prototype with plywood tonight with various distances: 1", 2" and 3" between each eye. What should we expect?
Unread 17-01-2011, 13:47
Jogo Jogo is offline
FRC #0353 (Pobots)
Jogo is on a distinguished road
There are some tips in the line tracking tutorial here: http://decibel.ni.com/content/docs/DOC-8923.
Unread 17-01-2011, 17:38
http://decibel.ni.com/content/docs/DOC-14730
Reading through this I found to start around two inches and tweak it from there.
Unread 17-01-2011, 21:12
wilsonmw04's Avatar
Coach
thanks for the white paper. Great place to start. We got our bot tracking a line in a few minutes. It's not competition ready yet, but it's a great place to start!
