Go to Post Inspectors are your friends and are there to make sure you are safe and legal to compete. - Al Skierkiewicz [more]
Unread 17-01-2011, 18:16
SamRI SamRI is offline
FRC #2443
SamRI is an unknown quantity at this point
Mini bot Brain
Is the brain for the mini bot really a Nxt brain or is it something else, and also what is the programming language we can use to program the mini robot?
Unread 17-01-2011, 19:10
Emanforlife's Avatar
Emanforlife Emanforlife is offline
Jock
AKA: Emmanuel
FRC #2990 (Hotwire Robotics)
Emanforlife is an unknown quantity at this point
Re: Mini bot Brain
The Lego NXT is the brain, and you can use what the FTC team's use which is RobotC to program the robot.
Unread 17-01-2011, 19:15
EricH EricH is online now
Re: Mini bot Brain
Depends on whether you opt to use the NXT. Yes, it is optional. I'm sure you can come up with something using a pair of light switches and/or some limit switches if you wanted to. If you do use the NXT controller, don't forget to disable Bluetooth.
Unread 17-01-2011, 21:37
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Re: Mini bot Brain
I've been thinking about this lately and have come to the conclusion that you could just wire up the mini bot to always be turning the motors, if that's how you're doing it, and completely get rid of the brain. It would save weight and space. Also being someone who is loaning out mini bots it saves me the worry of what would happen if a NXT brick were to fall from over 10 feet. I don't know about you guys, but I don't think it will be a good result. And to stop what is going to be the immediate next question if I don't answer it now. Yes, you could shield the brain to survive that fall, but again you add weight and space, as well as extra design time that could be used instead for practice.
The only problem I see with this is it would drain the battery during a match, but then again we have light switches we can use so why not turn it on when it hits the pole.
Originally Posted by wilsonmw04 View Post
Can the NXT handle the shock of hitting the top?
Hitting the top should be fine, but not hitting the bottom from the top
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Last edited by jamie_1930 : 17-01-2011 at 21:39. Reason: Wasn't thinking out what I wanted to put down
Unread 17-01-2011, 20:42
Techhexium Techhexium is offline
FTC #3555
Techhexium has a spectacular aura aboutTechhexium has a spectacular aura about
Re: Mini bot Brain
As others have mentioned the NXT is the brain, and you can either program in RobotC or in LabView. To program the motors with the NXT and RobotC / Labview, you will need a HiTechnic Motor Controller for TETRIX which cost $80 ($55 if you're in FTC team).
Unread 17-01-2011, 20:46
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Re: Mini bot Brain
Unread 17-01-2011, 21:28
FTC #3555
Re: Mini bot Brain
Although one of my team members once dropped a NXT to the floor and it still works, I doubt it because the NXT would have to withstand the shock multiple times. Most FTC teams cover their NXT so it that it is visible and protected by metal rather than leaving it exposed.
Unread 17-01-2011, 21:38
wilsonmw04's Avatar
Coach
Re: Mini bot Brain
I run FIRST FTC 35. It's not the exposure that worries me. It's the acceleration/forces that the brain will be regularly subjected to while riding on the backs of FRC bots. We have had several occurrences of our NXT freezing after a hit during FTC season. I am hesitant to rely on them at this moment.
Unread 17-01-2011, 22:31
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: Mini bot Brain
I suspect many mini-bot brains will have 1 bit memory, and the processor will only understand 1 instruction....
Unread 17-01-2011, 22:33
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: Mini bot Brain
I see no reason whatsoever to add an NXT.
Unread 17-01-2011, 22:37
wilsonmw04's Avatar
Coach
Re: Mini bot Brain
Here's one: Weight = more work needed to reach the top. If power is constant among the minibots, then the one that is lightest will win.
Unread 17-01-2011, 23:40
bobosalad's Avatar
bobosalad bobosalad is offline
FRC #2518 (Spartans of St. Jude)
Team Role: Driver
bobosalad is an unknown quantity at this point
Re: Mini bot Brain
so do we need to have a "brain" in the mini bot or can it be simple switch electronics?
Unread 17-01-2011, 23:43
Re: Mini bot Brain
Brain optional. IIRC, Q&A clarified this already.
Unread 17-01-2011, 23:51
Chris is me's Avatar
AKA: Pinecone
Re: Mini bot Brain
Adding an NXT would not remove weight.
Unread 18-01-2011, 06:47
wilsonmw04's Avatar
Coach
Re: Mini bot Brain
Yeah, funny what you think when you don't see the negative in a statement, hmm? My Bad.
