Go to Post Unlike robot design, in the clothing world there's no such thing as too much pocketing - Jaci [more]
Unread 17-01-2011, 19:12
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
Rack and pinion distance Help
I need to find the distance of one rotation of a pinion in a rack and pinion setup. I need a formula because I'm programming it and I can change the distance i need easily.
So if i have a rack (movable) with a pinion (stationary) in my hands i need to know how far the rack moves with one rotation of the pinion. What do i need to measure in order to know. (example teeth #, teeth length, ect.)
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
Unread 17-01-2011, 20:37
beiju's Avatar
beiju beiju is offline
Growing Chief Delphi Addict
AKA: Will Pryor
FRC #3120 (RoboKnights)
beiju is an unknown quantity at this point
Re: Rack and pinion distance Help
I would expect that distance to be the circumference of the pinion. If you need complete precision, and want to avoid any math errors, mount it in its final configuration and simply measure.
I’m interested to know where you got the rack. I don’t recall us having one from this or previous KOPs, and our team isn’t very familiar with where to buy such things.
Unread 17-01-2011, 20:51
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Calculate the circumference based on the pinion gear's pitch diameter.
circumference = Pi * pitch diameter
You'll need to know the diametral pitch of the pinion gear your using along with the number of teeth.
pitch diameter = (# of teeth) / (diametral pitch)
So .......
circumference = Pi * (# of teeth) / (diametral pitch)
Ed Sparks
MECH TECH FRC-3959
Unread 17-01-2011, 21:45
FRC #0379
Thank you very much Mr. Sparks This ended a very long discussion with my brother, also I can finish programming.
As for your question beiju I have no idea where my team is getting them I'm not involved in that but I would say your best bet would be Andy Mark (http://www.andymark.com/searchresults.asp?cat=212) quick search.
Unread 17-01-2011, 21:50
rahilm's Avatar
rahilm rahilm is offline
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
McMaster Carr is a great place to get a lot of these things. For racks and pinions: http://www.mcmaster.com/#gears/=amxsji
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
