Go to Post *gasp* robot? what robot? we were suppose to build a robot? - LightWaves1636 [more]
Unread 17-01-2011, 19:13
JellyMan JellyMan is offline
Mentor, Team 3414
AKA: Jeff
FRC #3414 (Falcon Robotics)
JellyMan has a spectacular aura aboutJellyMan has a spectacular aura about
Window motors in parallel
We are considering using two window motors in parallel to power a lifting arm. Since worm gear transmissions cannot be back-driven, and since the motors would be working together on the same axis, we are concerned that they may bind up.
Does anyone have experience with this?
If so, how did you control both motors?
Thanks.
Unread 17-01-2011, 19:16
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
Re: Window motors in parallel
each motor must be on its own spike victor or jaguar. you can provide them with the same signal using a PWM "y" cable
Unread 17-01-2011, 19:21
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
I would strongly suggest using the FP, BaneBot 550, or Banebot 775 motors instead of the Denso window motors to power an arm, as the Denso window motors are actually among the least powerful motors in the KOP. They are also prone to overheating and tripping their internal thermal circuit breaker if you try squeezing every last Watt out of them.
Art Dutra IV
世上无难事,只怕有心人.
Unread 17-01-2011, 20:13
Mentor, Team 3414
AKA: Jeff
Thanks for the fast replies!
The FP motor (#0673) and gearbox was our first choice for the lifting arm, but only one FP came in the 2011 KOP, and we already allocated that FP motor to an elevator function. We have two FP motors (#9015) and gearboxes from our rookie 2010 KOP, but the Andy Mark website lists the 9015 motors as illegal for 2011. Any idea why?
We are still essentially rookies in experience and resources of all kinds (especially funding), so we are stuck trying to make do with the scraps we have. We'd like very much to make use of the 2010 FP motors.
Unread 17-01-2011, 20:34
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is online now
Coach
FRC #1086 (Blue Cheese)
I would look at the 4 Banebots motors that were in your kit this year. one (or two) of those should be able to do any job on your bot.
We used the window motors during our rookie year (2007) to lift our tube manipulator. We used them in "parallel" on the same axis. They work fine but we ended up having to assist them when a bit of surgical tubing to get past the tipping point of the arch.
Unread 17-01-2011, 21:07
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Window motors in parallel
With enough moment and weight, those motors can backdrive. I would recommend you test them and design an anti-backdrive mechanism if it proves out that you will need one.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 17-01-2011, 21:40
Mentor, Team 3414
AKA: Jeff
Thanks. We'll take a look at the Banebot motors. Can the pinion gears be pulled off the FP 9015 or 0673 motors and pressed onto the Banebots? Will the Banebot motors mount to the FP gearboxes without modification?
Regarding the rules, I've reviewed the 2011 FRC Manual, and Section 4.3.9 Motors & Actuators <R45> states: "Motors specifically permitted on 2011 FRC ROBOTS include: A. all motors, actuators, and servos listed in the 2011 KOP Checklist". The checklist actually lists "FisherPrice Gearbox, 12VDC w/ 16 tooth pinion, -9015 motor". If the 9015 motor is illegal, then that seems to be contradicted by the 2011 checklist. If not for the statement on the AndyMark website, I would not have given it another thought.
Unread 17-01-2011, 21:53
maddoctor90's Avatar
maddoctor90 maddoctor90 is offline
AKA: Matt
FRC #2481 (Roboteers)
maddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to beholdmaddoctor90 is a splendid one to behold
We used two of the window motors in parallel last year on an winch that lifted up an arm to attach a hook to the tower. We then used a CIM to to lift the robot. The two windows motors would probably work fine, but like others have said, the Banebots motors would probably work better for your application if you can make them work.
Unread 17-01-2011, 21:56
AndyH's Avatar
AndyH AndyH is offline
FRC #1098 (Rockwood Robotics)
AndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud ofAndyH has much to be proud of
Our team 1098 used a left and right wimdow motor connected with a shaft between the couplers to run our cam kicker last year. Worked GREAT. One motor would just stall but the 2 motors did the job. The programming team got them to run together perfectly, seperate outputs to seperate Jaguars.
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
The idea that worm gears can't be backdriven is a bit of a misconception. It actually depends on the design of the system—some high-efficiency worm gears can definitely be backdriven. (See page G-57 here for more details.)
As Tytus explained, they can't be electrically in parallel, only mechanically. But in that configuration one failure in a motor or electrical component will probably lock up your arm, or worse.
