Go to Post Good robots with bad drivers can lose. Bad robots with good drivers can win. Good robots with good drivers can dominate. - James Tonthat [more]
Unread 17-01-2011, 20:16
Bethie42's Avatar
Bethie42 Bethie42 is offline
AKA: Bethany Carlson
FRC #0956 (Eagle Cybertechnology)
Bethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to beholdBethie42 is a splendid one to behold
Re: Robot Code and Communications disappear when Enable is pressed
The same thing happened to us just today. We appear to have 'fixed' it by commenting out any code which deals with switches/buttons on the driver station [we are testing stuff on last year's bot and DS].
I'm guessing there could be other problems [we saw a watchdog error at one point....] but if you've got any switch/button stuff going on, try commenting it out.
Hope that helps, we pulled our hair out over it....
Robot is now a verb.
We're back to square one...while we're at it, let's redesign square one!
Team 956: Celebrating ten years of FIRST!
Team record 2002-2011
2002: Highest Rookie Seed, AOR
2003, 2006, 2012: Xerox Creativity Award, AOR
2006: Semi-finalist, Sacramento Regional
2009: Quarter-finalist, AOR
2010: Quarter-finalist, AOR
2011: Semi-finalist, AOR, and Dean's List finalist, AOR
Personal record:
2008: Lead scout
2009: Lead scout, publicity
2010: Lead scout, publicity, fundraising, Chairman's, videography
2011: Team captain, lead programmer, fundraising, Chairman's, publicity, wrench-turning, Dean's List finalist at Autodesk Oregon Regional
Unread 21-01-2011, 18:58
jwakeman jwakeman is offline
FRC #0063 (Red Barons)
jwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nice
I would make sense that the robot code light would go out if your software is crashing when you enable. If both are really going out maybe you are pegging the cpu and so the cRIO can't maintain the comm link anymore either.
Unread 21-01-2011, 20:39
Unless you peg the CPU in a realtme thread, the comm and code light should not be impacted by user tele code. Instead, watch the LEDs on the cRIO to see if it is rebooting. That is the most likely cause. If that is the case, look at new tele code, or fire up the debugger.
Greg McKaskle
