Go to Post If you want to change the culture sometimes you need to change a little yourself - Koko Ed [more]
  #151   Spotlight this post!
Unread 12-01-2011, 17:45
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Team Update #1
Originally Posted by wilsonmw04 View Post
With that mind set, you have already lost. You are limiting yourself. Every year there is someone who states, "GAH! these rules are going to make sure that all the robots look/play alike. How Boring!" Every year I am amazed at the ingenious and creative ways teams go about solving the challenges in both FRC and FTC. So you can continue to think along these same lines and get what you expect, therefore proving yourself right, or you can try and look beyond those limits you are placing on yourself.
I guarantee someone has already designed the best minibot this year. It will be something that other teams couldn't get to work or thought of but tossed the idea aside as impractical.
Please see my post above about physics. The fundamental issue here is that we're given exactly one method of converting stored electrical energy into mechanical energy. This method limits you to, at most, 16.8W of mechanical power. This gives you a hard and definite limit of just how fast you can lift X lbs to Y inches. If the GDC allows minibots to expand or detach parts, then there's discussion to be had on whether to fire up something light, or drag the entire minibot up the pole.
It looks pretty certain that the GDC ISN'T going to allow expanding minbots or detachable parts, so your only option is to haul the entire minibot up the pole. So you know right away the you're hauling 2 motors and a battery up the pole, and you want to absolutely minimize any wasted energy. You want every last erg you can get to go into lifting the bot. It really, really focuses your design.
What about the bot that spins around the pole as it goes up? Nope, all that rotational kinetic energy is a waste. Big honkin' wheels? Nope, more wasted rotational energy. Lots and lots of gears? And waste all that energy in friction in the bushings? Umm... maybe a flag to wave around at the top? Nope, don't have the grams to spare. These constraints pin you down to the absolute bare minimum necessary to get the job done. The most successful minibots will have the minimum necessary wiring, maybe one gear step up (yes, up), a battery, and the lightest frame possible. The only real question open to you is how you latch the minibot onto the pole as quickly and high as possible, within these other constraints.
So it's not the fun, crazy, creative kind of engineering we get to do on the rest of the robot. It's the focused, detailed, iterative kind of engineering that's rather less popular, but rather more common.
  #152   Spotlight this post!
Unread 12-01-2011, 17:59
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: Team Update #1
Originally Posted by Kevin Sevcik View Post
...the focused, detailed, iterative kind of engineering ...
... is the kind that really matters.
It's the way we get to things that really work, really well, for a really long time. (Must think of some examples...)
Ah, here's one: Dave's other car.
Richard Wallace
since 2003
  #153   Spotlight this post!
Unread 12-01-2011, 18:43
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
Re: Team Update #1
As a teacher of conceptual, standard and AP Physics, I understand the principles behind most mechanical processes. I stand by my statement that you are already limiting yourself in your approach.
have anyone thought about this?:
<G59> TEAMS must retrieve MINIBOTS from the TOWER quickly and safely after each MATCH. Violation: The FIELD crew will retrieve the MINIBOT if the TEAM does not. A second violation may result in a YELLOW CARD.
Can you make a bare bones minibot that you can SAFELY remove from the tower in less than 1 minute?
  #154   Spotlight this post!
Unread 12-01-2011, 19:24
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Re: Team Update #1
You do realize that we have a several hundred dollar control system in charge of the robot, right? Give yourself a deployment arming button and start a timer as soon as the robot enters enabled teleop. If you're armed and the timer hits 110 seconds, fire the minibot. If you're depending on your driver's reflexes, you're wasting valuable time.
Kevin,
I'm certainly no expert, but I believe that in past seasons there have been up to several seconds of variation in match length during FRC Regional matches.
Talk to a few folks (some FTAs maybe?) who can confirm or deny my fuzzy suspicion before putting too much faith in being able to legally deploy the mini-bots exactly 110 seconds after your robot reports (to itself) the match has been started.
Blake
  #155   Spotlight this post!
Unread 12-01-2011, 19:41
Nemisis's Avatar
Nemisis Nemisis is offline
Frame/Body/Motors
FRC #2389 (S.T.O.R.M.)
Nemisis will become famous soon enough
Re: Team Update #1
I'm very excited about the 84'!! however i'm not as joyful bout the minibot ideas... this is going to hinder design work just a bit... should still be interesting thou!
RHS Senior 2011
  #156   Spotlight this post!
Unread 12-01-2011, 20:09
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Team Update #1
Originally Posted by JesseK View Post
The only thing that really NEEDS to be TETRIX on the minibot are the battery, motors and wheels.
(emphasis mine) I'm not so sure that <R92> states that I cannot fabricate my own wheels from aluminum sheet and tube (for example). Just sayin'
Originally Posted by SteveGPage View Post
Getting frustrated, he yelled, <snip>
It may have helped that the entire contraption was built by the lowest bidder...
Originally Posted by sanddrag View Post
With a solid understanding of the physics and engineering principals associated with the MINIBOT challenge, the possible design solutions converge to one winning concept.
Exactly. So which team will be able to wring the most from their pinewood derby car minibot? The team that understands the design constraints best. Maybe it IS a competition to see who sucks least, but I for one welcome the opportunity to blow your doors off.
Bring it on.
  #157   Spotlight this post!
Unread 12-01-2011, 20:12
Nemisis's Avatar
Frame/Body/Motors
Re: Team Update #1
Good luck with that Sir! Team 2389 is in full swing and is working nonstop to make this year the absolute Best!
RHS Senior 2011
  #158   Spotlight this post!
Unread 12-01-2011, 20:16
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
Re: Team Update #1
Absolutely, this is not an engineering challenge.
I can easily think of several ways to get a bare bones bot off the pole safely in less than 30 seconds (and they don't involve a stick chainsaw as Dean demonstrated). After all, we're planning a sub-one second deployment. Why should it take up to a minute to retrieve the little critter?
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
  #159   Spotlight this post!
Unread 12-01-2011, 20:20
Boydean's Avatar
Boydean Boydean is offline
The Blue Alliance
Boydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant future
Send a message via AIM to Boydean
Re: Team Update #1
I find this new contraint quite enjoyable. Then again, I'm not on a team.
There has always been talk from year to year about "standardizing" certain parts of the robot across teams to allow them to be able to be switched out at competitions. I think FIRST just laid a golden egg right in your lap to do something like this and make it actually happen (in fact, they are encouraging it).
Forget about the "lack of innovation" that has come from this rule, and think about how fun it'll be brainstorming with other teams in the pit to get their minibot to work with your hostbot.
Just my two cents.
  #160   Spotlight this post!
Unread 12-01-2011, 20:22
Nemisis's Avatar
Frame/Body/Motors
Re: Team Update #1
I must agree!
RHS Senior 2011
  #161   Spotlight this post!
Unread 12-01-2011, 21:09
Alexa Stott's Avatar
Alexa Stott Alexa Stott is offline
All I do is twin.
AKA: elixir
FRC #0025 (Raider Robotix)
Alexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond repute
Send a message via AIM to Alexa Stott
Re: Team Update #1
Originally Posted by Nemisis View Post
I must agree!
...with?
|Email:alexastott[at]gmail.com|Facebook|@zelixir|Google+|
[University of Maryland Computer Science, Psychology]
[Brunswick Eruption]
  #162   Spotlight this post!
Unread 12-01-2011, 21:11
Nawaid Ladak's Avatar
Nawaid Ladak Nawaid Ladak is offline
The Banana People Are Awsome!
AKA: Nawaid Ladak
FRC #0945 (Team Banana)
Team Role: Tactician
Nawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant future
Send a message via AIM to Nawaid Ladak Send a message via MSN to Nawaid Ladak Send a message via Yahoo to Nawaid Ladak
Re: Team Update #1
Mods, could this thread be given a 24-hour cooldown? I think we all need a break.
I second this request. Hopefully this gets people to stop complaining and start working on their teams bots.
"When you make a mistake, admit it, correct it, and learn from it - immediately."-Stephen Covey
I can still learn from this quote, how about you?
Nawaid Ladak
2003-2006 FRC # 1402: Freedom Force. Scouting
2007 FRC # 1694: RoboWarriors. Mentor
2008-Present FRC # 945: Team Banana. Mentor
Contact me
E-mail: LadakN (at) GMail (dot) com
Twitter / Facebook / Youtube
  #163   Spotlight this post!
Unread 12-01-2011, 23:16
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Re: Team Update #1
I was thinking the same thing. 24 hour rest. Reopening tomorrow evening.
We do not stop playing because we grow old;
we grow old because we stop playing.
  #164   Spotlight this post!
Unread 17-01-2011, 17:58
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
Re: Team Update #1
Even with the massive constraints placed on the minibot design, it will still be difficult to create a final product that attaches to the pole, and has enough traction to adequately grip the pole. It's still going to be exciting to see which teams come up with novel ways to increase traction, novel methods of attachment, and creative ways to lighten the whole system.
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
  #165   Spotlight this post!
Unread 17-01-2011, 20:32
bassoondude bassoondude is offline
1293 Awards and Rules Captain
AKA: Miller
FRC #1293 (D5 Robotics)
bassoondude is a splendid one to beholdbassoondude is a splendid one to beholdbassoondude is a splendid one to beholdbassoondude is a splendid one to beholdbassoondude is a splendid one to beholdbassoondude is a splendid one to beholdbassoondude is a splendid one to behold
Re: Team Update #1
Doesn't the blue box under section 4.13.15 technically allow an FTC team who is not registered for the competition to win the coopertition award?
2011 Palmetto Regional: Semi-Finalists
2010 Palmetto Regional: Semi-Finalists
2009 Palmetto Regional: Quaterfinalists
