Go to Post The propagation of the idea of making FIRST into a perfectly fair competition is just silly. - Andy Baker [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
  #46   Spotlight this post!
Unread 16-01-2011, 13:30
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
Re: Updated CAN Jaguar Issue
Originally Posted by ozrien View Post
Be sure to use the latest 2CAN plugin from our site....
http://www.crosstheroadelectronics.com/2CAN.htm
The plugin that's installed with the FRC image is very old (early 2010). Requesting firmware version does not work with that plugin.
More info here...
http://forums.usfirst.org/showthread...highlight=2can
Is it possible that the serial plugin is also old? In that event we will try to load the plugin we used in December and report back
]EDIT[
Nope still broken.
  #47   Spotlight this post!
Unread 16-01-2011, 13:56
Adamsmasher Adamsmasher is offline
FRC #1646 (Boiler Precision Guessworks)
Adamsmasher is an unknown quantity at this point
Originally Posted by drakesword View Post
When you used the 2CAN did you load the 2CAN plugin instead of the serial can plugin?
I would like to know if the 2CAN is indeed working. If it is we will switch temporarily
After updating to the latest 2CAN plugin the 2CAN is communicating with the jags and the cRIO fine, but we still get UncleanStatusException when we try to initialize.
  #48   Spotlight this post!
Unread 16-01-2011, 18:44
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
The serial plugin is not old. When the v25 Image was created, I put the wrong 2CAN plugin in the image. That will be fixed in the update.
  #49   Spotlight this post!
Unread 16-01-2011, 18:47
This is an issue with the Java implementation. The C++ and LabVIEW CANJaguar implementations are not affected.
Please see this tracker: http://firstforge.wpi.edu/sf/go/artf1306
-Joe
  #50   Spotlight this post!
Unread 16-01-2011, 19:54
AKA: Bryant
Thanks so much for working on this problem over the weekend. Team 346 appreciates it.
  #51   Spotlight this post!
Unread 16-01-2011, 21:03
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
-Joe
Glad to read this. Team 20's controls team spent the greater portion of this weekend figuring this out for ourselves. Once we reimaged the CRIO back to last year's image and loaded the old Netbeans plugins and had them work flawlessly, we called it a day. Thanks for your work!
  #52   Spotlight this post!
Unread 17-01-2011, 14:17
AKA: Bryant
Hey Joe,
when could we expect the update to be pushed through. Our team is eager to run our chassis with can asap so drivers can practice.
  #53   Spotlight this post!
Unread 17-01-2011, 17:05
vinnie's Avatar
vinnie vinnie is offline
FRC #3309 (Friarbots)
vinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond repute
We here at team 3309 have created a tutorial for our workaround to get CAN working before the official fix is released. Go to our wiki page http://goo.gl/ytxaL to see the tutorial.
  #54   Spotlight this post!
Unread 17-01-2011, 17:42
Hey Joe,
I anticipate it will be out later today or possibly tomorrow.
-Joe
  #55   Spotlight this post!
Unread 17-01-2011, 20:11
Hey Joe,
It is posted now! You can download it at FIRST Forge or you can use the automatic update in NetBeans.
-Joe
  #56   Spotlight this post!
Unread 17-01-2011, 20:38
AKA: Bryant
-Joe
For those less aware . . .
http://firstforge.wpi.edu/sf/frs/do/viewRelease/projects.wpilib/frs.wpilib_java_update_for_2011_frc.wpilib_java_fr c_2011_update_ve_1
is where the update is. Unload all of the older nbm files and load the 5 new ones.
  #57   Spotlight this post!
Unread 17-01-2011, 20:43
vinnie's Avatar
Thanks for getting it fixed!
But now I am having a new problem.When I tried to call getSpeed(), it would constantly return 0.0. I looked in the javadoc and it said "returns speed of the motor in RPM based on the configured feedback." How do I configure it so I get a real speed value?
  #58   Spotlight this post!
Unread 17-01-2011, 20:45
Or if you used the installation over the network, just update.
  #59   Spotlight this post!
Unread 17-01-2011, 21:04
Have you configured a reference sensor?
A call like:
myJag.setSpeedReference(CANJaguar.SpeedReference.kQuadEncoder);
-Joe
  #60   Spotlight this post!
Unread 17-01-2011, 21:13
vinnie's Avatar
Thanks, I set a position reference but I guess I forgot to set a speed reference. This is the first year that we're using CAN so we still have a lot to learn.
