Go to Post Don't be too arrogant as to think that just because you didn't invent it, it is not useful. - ptan [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 17-01-2011, 20:16
computerish computerish is offline
FRC #0619
computerish is an unknown quantity at this point
BDC-COMM does not recognize Jaguars
We are trying to update our old Jaguars to the latest firmware. We have a USB to serial converted plugged into a serial to CAN adapter, plugged into a Black Jaguar on the left port. The right port has a CAN terminator in it.
BDC-COMM recognizes the serial port, but doesn't recognize the Jaguar. The Jaguar continues to blink slowly yellow.
Unread 17-01-2011, 22:15
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Re: BDC-COMM does not recognize Jaguars
verify your pinouts
the serial to can should be DB9 pin 3 to RJ-12 pin 1, , pin 5 to 5, and pin 2 to 6. the adapter should also have a 100 ohm resistor between pins 3 and 4 on the RJ-12
the terminator should have a 100 ohm resistor between pin 3 and 4. did you directly crimp the resistor? if so, it may have shorted... i usually crimp wires in and solder the resistor to the wires to prevent that.
Unread 18-01-2011, 20:46
FRC #0619
Thanks for your help! Turns out I didn't get the CAN terminator plugged all the way in. You really gotta wait for it to snap.
Checking our connections on the DB9 to RJ12 did help, though, since we discovered one of our connectors wasn't wired correctly.
Unread 18-01-2011, 21:16
ratdude747's Avatar
AKA: Larry Bolan
good to hear. i hate it when that happens... i went through a db9 to rj12 adapter finding out that the colors are backwards... but since we found them for $.50 a pop and bought 5, I had 4 i could make.
