Go to Post in other words, "always have something to do that will change up your life" - Nawaid Ladak [more]
View Poll Results: Mecanum or 6WD
Mecanum 90 40.36%
6WD 133 59.64%
Voters: 223. You may not vote on this poll
  #91   Spotlight this post!
Unread 12-01-2011, 22:09
EagleEngineer's Avatar
EagleEngineer EagleEngineer is offline
AKA: Michael Amoun
FRC #1138 (Eagle Engineering)
EagleEngineer is an unknown quantity at this point
Re: Mecanum or 6WD
To get across the field.
  #92   Spotlight this post!
Unread 12-01-2011, 23:33
Dr Theta's Avatar
Dr Theta Dr Theta is offline
Lead Mentor
AKA: Derek Messer
FRC #2232 (Deus Ex Machina)
Dr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud of
Re: Mecanum or 6WD
I really think whatever drive you choose is less important than it being designed properly, the people programming it, and the person driving it. Our team will be using mecanum again this year, not because it is inherently superior to all other drive platforms, but because we have experience with it, it works well with our strategy, we know how to program it for our purposes, and we have a driver who is crazy good with it. It isn't so much about the drivetrain, but how you use it.
  #93   Spotlight this post!
Unread 12-01-2011, 23:40
2bkrul's Avatar
2bkrul 2bkrul is offline
Whats tht burnin smell..oh the Jag!
AKA: Brandon Krul
FRC #0964 (Bedford Robotics)
2bkrul is an unknown quantity at this point
Re: Mecanum or 6WD
6WD but have 2WD and 4W Floaters...either with Omni's or the Lunacy wheels
"Building robots is a lot better with doughnuts around"
-Team 964 2010 Team Motto
Team 964 on TBA!
The Home of Bedford Robotics!
  #94   Spotlight this post!
Unread 12-01-2011, 23:42
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Mecanum or 6WD
Now my team captain said we are doing the 6 wheel drive with the middle wheel slightly lowered. We are extremely tight on budget this year, so any other would be asking for too much (except for 4 wheel drive)
  #95   Spotlight this post!
Unread 13-01-2011, 08:12
davidcone315 davidcone315 is offline
FRC #3154 (Robo-Razziatore)
Team Role: Student
davidcone315 will become famous soon enough
Re: Mecanum or 6WD
Originally Posted by Stephen of REX View Post
Depends how much you drop by. If you drop the center wheel by 1/8 of an inch (which I believe is enough to get the desired effect) then rocking should be minimal, especially if you have distributed your weight to prevent rocking while hanging.
The rocking is the reason why we want to use a mecanum drive
  #96   Spotlight this post!
Unread 17-01-2011, 22:46
Charmander's Avatar
Charmander Charmander is offline
None #1714
Charmander can only hope to improve
Re: Mecanum or 6WD
Mecanum isn't going to help much if you can't get to the scoring area. If a team on the other alliance plays defense, mecanum loses its value since it can't push
  #97   Spotlight this post!
Unread 17-01-2011, 22:51
Chris is me's Avatar
AKA: Pinecone
Re: Mecanum or 6WD
Rocking has at most maybe 1/2" effect on an extended manipulator. If you need that much precision to score, you won't be scoring frequently.
  #98   Spotlight this post!
Unread 17-01-2011, 22:58
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: Mecanum or 6WD
Agreed! Last year was the year that rock was bad when dealing with ball manipulators and lifting off the ground or losing your ball. That is what made 8wd so popular. We almost went with 8wd to eliminate rock, but choose 6wd since it was faster to make, cheaper, easier, and the rock wasn't going to affect our design.
1058 PVC Pirates 2016 - xxxx
  #99   Spotlight this post!
Unread 17-01-2011, 23:14
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Mecanum or 6WD
may not be as able to push as well but if it dances around the defense it doesn't need too.
  #100   Spotlight this post!
Unread 17-01-2011, 23:20
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Mecanum or 6WD
Then I can argue that the defense is doing its job; the more time you take away from the enemy, the less they score. That is an argument why my team should go defensive this year, but everyone wants to be quarterback and score.
  #101   Spotlight this post!
Unread 17-01-2011, 23:23
rutzman rutzman is offline
AKA: Ryan
FRC #2614 (MARS)
rutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant future
Re: Mecanum or 6WD
Mecanums strafing ability allows for added maneuverability.
6WD allows for more traction.
Neither is inherently better than the other in a 1v1 match up.
The aspect that pushes that match up towards one side is going to be the amount of practice the drivers get with their robots, and robots with similar drive bases. If a defensive bot has experienced drivers that have had a couple years and a practice bot, and the mecanum offensive drivers have never touched a holonomic drive in their lives, the mecanum drive will be completely dominated. However, if the mecanum drivers have spent a hundred or more hours with the 3-axis joystick in their hands and the 6WD drivers are taking their first turn behind the drivers' station, a juke and a spin is all it will take to get into the scoring zone.
  #102   Spotlight this post!
AKA: Pinecone
Re: Mecanum or 6WD
Can you point to a video of a mecanum drive that's ever done that?
  #103   Spotlight this post!
Unread 18-01-2011, 05:36
goffchris goffchris is offline
FRC #1884
goffchris is an unknown quantity at this point
Re: Mecanum or 6WD
We are going to test both. We have a team working on each type. We have found our past mecanum systems to be plenty fast. I also think that they are advantageous this year with the narrow feeder chute. It might be easier to make lateral corrections to our position with the crabbing ability. Rather than having to back up and turn, we can make small moves sideways if our tubes are a bit off.
As for dealing with defenders, our drivers have been able to use crabbing to outmaneuver less agile robots. We are sometimes a bit slower in a straightaway than 6 wheeled robots, but haven't been significantly disadvantaged by that.
We are interested in whether the rocking motion of the CA drive will make use vulnerable to tipping when extended. Jury is still out, of course.
  #104   Spotlight this post!
Unread 18-01-2011, 10:02
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Re: Mecanum or 6WD
I sure hope to see a spin move this year. Very cool.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
  #105   Spotlight this post!
Unread 18-01-2011, 10:28
Joining the 900 Meme Team
FRC #0079
Re: Mecanum or 6WD
Not exactly, I do have a couple of pictures of 2337's mecanum drive shoving HOT up the bump though.
The key to either system is having a skilled driver who communicates effectively with the coach and his other driver. There are benefits and drawbacks to everything and we must be able to effectively figure out which downsides we can live with and which we can't.
I personally am doing either 6wd or 8wd this year, we talked about mecanums (3450/314) but we are building multiple bots and doing that makes cost highly prohibitive. (4 gearboxes + 4 mecanum wheels for each bot) I am also an alumni from the Martian "defense" era. The best defense is having more traction than your opponent. For the record we also considered doing a swerve drive but buying 3 Revolution modules or 3 WildSwerve modules was out of the question price wise.
