Go to Post Adaptability is the key folks. Your job will not be the same 10 years from now (when I retire), or 20 years or 30 years from now. The tools and systems you use will change, and you must be able to adapt along with them. - Bill Moore [more]
Unread 13-01-2011, 19:24
DaBossToss's Avatar
DaBossToss DaBossToss is offline
FRC #1318 (IRS)
DaBossToss is an unknown quantity at this point
2011 image problems
I can not figure out where to find to 2011 cRio image. I have updated everything else. so this is very important please reply.
Unread 13-01-2011, 20:39
mathgeek01 mathgeek01 is offline
C++ Ninja in Training
FRC #3397 (Robolions)
mathgeek01 is an unknown quantity at this point
Re: 2011 image problems
I believe that the 2011 Imaging tool is found in the Utilities Software update. Once you install that, it can be found at Start>>All Programs>>LabVIEW 8.6>>FRC CRIO Imaging Tool.
I am having a problem of my own with imaging the CRIO.
When I try to reimage with the 2011_v25 image set for WindRiver code, I get these errors:
Unable to complete operation because of unexpected error:
Error 63 occurred at TCP Open Connection in NI_InternetTK_FTP_VIs.lvlib:FTP Open Session.vi->NI_InternetTK_FTP_VIs.lvlib:FTP Get Multiple Files and Buffers.vi->NI_InternetTK_FTP_VIs.lvlib:FTP Get File.vi->ConfigUtility.lvlib:OpenRemoteConfiguration.vi->ConfigUtility.lvlib:ReImageTarget.vi->ConfigUtility.lvlib:Dialog.vi
Possible reason(s):
LabVIEW: Serial port receive buffer overflow.
LabVIEW: The network connection was refused by the server. For TCP/IP, make sure the server is running and listening on the port you are trying to use. Firewalls can also cause a server to refuse a connection. For VI Server, make sure you have enabled VI Server from Tools>>Options>>VI Server:Configuration.
Has anyone had similar problems, or an idea of how to solve this?
Unread 14-01-2011, 01:52
The second explanation is the one to pay attention to.
Turn off firewalls, turn off any NICs not in use -- typically this means to turn off wireless and connect with a cable.
In some situations, it is more likely to succeed if the computer and cRIO are both connected through a router than a direct cable.
Why? Imaging the cRIO involves broadcasting to locate cRIOs, regardless of their IP. Then the laptop must communicate with the cRIO, set it to the correct mode, download the image, and the cRIO reboots. The cRIO now has a generic IP setting -- this used to be 0.0.0.0, but should now be DHCP. The computer must locate the generic cRIO and configure its networking, name, etc. Then it reboots again. In other words, it has many potential steps that can fail due to timing conditions with DHCP or broadcast mechanism. These include computer drivers, security settings, routing tables and NIC configurations, etc.
Please try the steps above or follow one of the trouble shooting lists available from NI.com/first in the support section.
Greg McKaskle
Unread 14-01-2011, 10:49
When asking for help troubleshooting a problem, it's usually not helpful to use words like "everything". For example, if there were 5 steps, and you only knew about 4 of them, you'd say you did "everything" when in reality you didn't. In this case, listing the updates you installed would be helpful. If you did miss an update, you probably would have had an answer in an hour or two, rather then a day. Asking good questions takes time and practice, but saves time in the long run.
The imaging tool is installed in the FRC Tools & Utilities update. The image that the imaging tool uses is installed in the update for the language that you are using (LabVIEW, C++, or Java).
Unread 14-01-2011, 12:41
G_rupp's Avatar
G_rupp G_rupp is offline
FRC #1108
G_rupp is an unknown quantity at this point
You might try changing the position of the "No App" switch. I had a similar error last year after installing the CAN interface into the RIO when trying to install a new image. The only way I was able to do any debugging or deploy code for competition was to change the switch. Just remember to switch it back
Unread 14-01-2011, 20:13
Thanks, Greg. I turned off Windows Firewall and the wireless bridge, and was able to image the CRIO successfully.
Unread 17-01-2011, 12:39
ehlochbr ehlochbr is offline
FRC #2990
ehlochbr is an unknown quantity at this point
I'm having a similar problem as the first post in this forum. I can't find the image file (v25). I've downloaded the utlities update but the NI folder on the driver station doesn't contain labview 8.6 (which is where everyone says to look for the 2011 image file).
How do I get labview 8.6 on the driverstation? Thanks.
Unread 17-01-2011, 15:00
LabVIEW needs to be installed from the DVD supplied in the KOP.
If you have a usb DVD reader, you can use that.
If you have a large (4GB or better) memory stick, you can copy the contents of the LabVIEW DVD onto that and install it from there.
Be sure afterwards to install the LabVIEW update, Utilities, and Driver Station update.
Unread 17-01-2011, 17:12
FRC #2990
We've put LabView 8.6 on the driver station but when we open the cRIO imaging tool there are no image files. Where can we find the 2011_v25 image files for the cRIO? Thanks.
Unread 17-01-2011, 20:11
Now install the LabVIEW Update
Unread 17-01-2011, 23:13
sgrinde sgrinde is offline
FRC #3801
sgrinde is an unknown quantity at this point
I am also having problems with the cRIO imaging tool. I have no image files. I need help. Thanks!
Unread 18-01-2011, 07:21
You have no image after installing the LabVIEW Update?
Or if you are using Java or C++, did you install the associated language update?
Each of the language specific updates contains the appropriate cRIO image file.
There is a different one for each of the programming environments.
