Go to Post A lot of people posting without first hand knowledge, that's fun. - Aren_Hill [more]
Unread 13-01-2011, 17:39
Re: Minibot Tetrix Modification?
The allowed lists is just that. You are allowed to use anything on the list. Per Update #1 you must use one battery and one or two motors.
Tytus, I think the air in your suit is getting a little thin, open the door and let some fresh air in.
Unread 18-01-2011, 02:05
vamfun vamfun is offline
Mentor :Contol System Engineer
AKA: Chris
FRC #0599 (Robodox)
vamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of light
Send a message via AIM to vamfun
Deri,
As long as your modification does not violate
<R93> Motors may not be modified with exceptions of those in Rule <R47>.
This rule negates making changes to motors or integral transmissions other than for mounting. if the gear is internal to the FTC motor, then you may not modify. If it is an FTC mechanical part, there does not appear to be a rule that prevents it.
I think I'm going to get a headache since it seems now that the gear_box on the FTC motor is not part of the motor and can be done away with or modified.
Tetrix motor/gearbox
This was not my earlier assumption and opens the flood gates to new ideas.
Are the connector/wires/fuse not part of the battery now?
Seems that there is no gauge requirement or circuitry restrictions.
Can we use uninsulated wire (with separation isolation) or enameled solid wire in the circuit?
Unread 18-01-2011, 07:35
As Chris has pointed out the Q&A has deemed the gearbox may be removed from the FTC motors. That will be passed along to the inspection teams.
