Re: Watchdog - no volt in DS
What you describe suggests that the cRIO does not have the proper image installed. What cRIO image version does the Driver Station report?
I took a look in the code and saw that an error is provoked in the Get Refnam VI of our 4 motor drive. I don't have the error number right now, but a search in Google showed that the error is probably caused by a difference between the computer version and the cRIO version. I would appreciate a link to download a new cRIO image (if there is one) as well as help with updating our classmate (imaging card doesn't work) and programing computer. |
There's your problem. The correct image at this time is v25.
Make sure you get all the Software Updates from the FIRST web site. When you run the Utilities and LabVIEW updates, the latest image will be placed on your computer. Use the cRIO Imaging Tool to put it on the cRIO. I don't have enough information about your Classmate problem to give you any useful advice. |
Thank you very much! Our robot works again. The problem was a failed LabVIEW update instlation, that failed to install V25 zip file.
