Go to Post So measure not by the masses, but by the sparks that you generate. - Kims Robot [more]
Unread 18-01-2011, 09:23
techplex's Avatar
techplex techplex is offline
Blake B
AKA: Blake
FRC #4909 (The Bionics)
techplex is just really nicetechplex is just really nicetechplex is just really nicetechplex is just really nice
Re: Using the NXT Light Sensor.
Do you know where we can get a pinout, for the sensors?
and or directions to hook it up to the analog module.
Blake
Electrical, Programming and Design
Creator FRC Q&A 2017
Mass FRC Team 4909: The Bionics
Maine FRC Team 5122: The RobOTies (2014-2015)
Maine FRC Team 2648: Infinite Loop (2008-2011)
Unread 18-01-2011, 10:14
Bot190's Avatar
Bot190 Bot190 is offline
FRC #0166 (ChopShop)
Bot190 will become famous soon enough
The documentation for The NXT brick, and the sensors is available from http://mindstorms.lego.com/en-us/sup...s/default.aspx under the hardware development kit. You should be able to figure out the pinout from those documents.
