Go to Post Dean's probably sitting in his chair saying "Dance puppets, dance!" - [more]
Thread Tools Rating: Thread Rating: 4 votes, 4.50 average. Display Modes
Unread 18-01-2011, 09:25
obsidianjeff's Avatar
obsidianjeff obsidianjeff is offline
former member, current mentor
AKA: Jeff
FRC #2450 (The Raiderbots)
obsidianjeff is an unknown quantity at this point
Re: Minibot climb rate
Originally Posted by JB987 View Post
Food for thought...4 way switches will indeed help you reverse your motors but there is a cost. Even stripped down they are relatively heavy and also one must consider the rate of the descent and the endpoint velocity as your bot strikes the base platform. Not sure what the effect on the field element will be. Has anyone tested a motor aided return to the base platform?
wouldn't a simple resistor on the switch be enough to make it drive slower in one direction but not effect the upwards movement?
"The tragedy of science: the slaying of a beautiful hypothesis by an ugly fact" - Thomas Huxley
