Go to Post FIRST doesn't graduate you from HS ... your performance in class (your grades) do. - Franchesca [more]
Unread 01-18-2011, 11:12 AM
johncap100 johncap100 is offline
FTC #0658
johncap100 is an unknown quantity at this point
problem building the example
I get the following error when i try to build the example default in the steps of the C++ programming guide provided at the FIRST website
any help is greatly appreciated
Build Started in Project 'DefaultRobot': 2011-01-12 16:49:28
Generation of makefiles started.
Folder "/OriginalDefaultCode" used in build target "OriginalDefaultCode" not found.
Build Finished in Project 'DefaultRobot': 2011-01-12 16:49:28 (Elapsed Time: 00:00)
