Go to Post "its not working because you didnt program it right" *wheel falls off* "never mind" - Nin_estarSaerah [more]
Unread 14-01-2011, 15:57
jackforey jackforey is offline
FRC #3717
jackforey is an unknown quantity at this point
Cool Our code won't stay on the robot/crio.
Our code that we keep having to build onto the robot won't stay so we have to run the main each time how can we fix this or is this normal?
Unread 14-01-2011, 17:31
Re: Our code won't stay on the robot/crio.
Do you do both of these actions?
  1. "Build"
  2. "Run as startup"
Unread 14-01-2011, 20:53
SuperS_5's Avatar
SuperS_5 SuperS_5 is offline
[Certified LabVIEW Developer]
FRC #1219
SuperS_5 will become famous soon enoughSuperS_5 will become famous soon enough
I don't know if you already saw this, but here is a good walk-through of that process.
http://www.frcmastery.com/labview-fo...-startup-code/
Mike B
Unread 16-01-2011, 15:33
tagayoff's Avatar
tagayoff tagayoff is offline
FRC #3512
tagayoff is a jewel in the roughtagayoff is a jewel in the roughtagayoff is a jewel in the roughtagayoff is a jewel in the rough
Follow this link to a video that shows how it'e done.
Unread 18-01-2011, 11:49
Eric Reed Eric Reed is offline
I am somebody now!
#0481 (De Anza Robotics Team)
Eric Reed will become famous soon enoughEric Reed will become famous soon enough
Build is greyed out...quick advice?
Unread 18-01-2011, 12:01
It looks like this, but with the word "Build" grayed out?
Does your Project Explorer window look different from this one in other ways as well?
Unread 18-01-2011, 12:03
Flyer522's Avatar
Flyer522 Flyer522 is offline
AKA: Holton
FRC #3753 (Raptor Robotics)
Flyer522 is an unknown quantity at this point
Are you deploying with the shown menu above? If so "Build" then "Deploy" should work.
The main toolbar menu might be grayed out in the beginning for build. I had that problem when I first started.
Team 3753 | Raptor Robotics
2011 Bayou Regional Highest Rookie Seed Award
2011 Bayou Regional Quarter-Finalist (w/ 1912 & 3672)
2012 Bayou Regional Quarter-Finalist (w/ 1912 & 1927)
Data is not information.
Information is not knowledge.
Knowledge is not understanding.
Understanding is not wisdom.
Unread 18-01-2011, 12:13
I am somebody now!
Aaahh...yes we have that, thanks. I was looking at the "Tools" drop-down menu.
Unread 18-01-2011, 12:23
The main toolbar Project->Build will be grayed out if no Build Specification is selected. It doesn't know what it is you want to build.
In the picture I posted the highlighted line is selected.
There can be more than one of these Build Specifications as you get more sophisticated.
Unread 18-01-2011, 21:32
umangv620 umangv620 is offline
Programming Captain
AKA: Umang
FRC #1403 (Cougar Robotics)
umangv620 will become famous soon enoughumangv620 will become famous soon enough
  1. "Build"
  2. "Run as startup"
When I permanently deploy, I don't choose Run as Startup... I just click Deploy since I just enable the code through Driver Station.
I'm not sure whether or not Run as Startup actually enables code as soon as you turn on the robot(like it did two years ago) since it (must?) receive an enable signal from the DS, but choosing Deploy itself might be safer.
Team 1403 Cougar Robotics
2009-2011 Programming Captain
2010
NJ-Regional - Chairmans Award
Unread 18-01-2011, 23:26
"Run as startup" is safer to use.
Both are functionally equivalent if you chose the "Always run deployed code at startup" option when you formatted/imaged your cRIO.
If you don't chose that option then the deployed code will not execute when you power up your robot and it'll just sit there on the field, like a rock.
A normal operational robot always has it's code running if it's on.
The Driver Station doesn't activate your code on the robot. It just enables/disables the outputs so your motors will do what your code has been telling them to do all along.
