Go to Post To my surprise, purple painted air tanks were illegal last year. AB - Andy Baker [more]
Unread 18-01-2011, 13:03
WPI Library RobotDrive::HolonomicDrive
Perhaps I am looking in the wrong places, but the attached screenshots are the only documentation I could find for RobotDrive::HolonomicDrive in the C++ WPI library. Is there more detailed documentation available elsewhere?
My specific questions are:
1) magnitude. what are the units, and the range? or is this a unitless -1 to +1 input ?
2) direction. Is this expected to be in degrees or radians? Where is zero, and is it CW or CCW?
3) rotation. Is this positive CW or positive CCW? What are the units? rpm, degrees per second, radians per second? Or is it unitless -1 to +1 ?
And a 4th question:
4) Is there someplace to download (I do not have the DVD) the library source code for inspection purposes only? i.e., without an installer.
Thank you.
Name:	Cpp Holonomic Drive ref chm.png
ID:	9722  Click image for larger version
Name:	Cpp Holonomic Drive ref PDF.png
ID:	9723  Click image for larger version
Name:	Cpp Holonomic Drive pgm guide PDF.png
Unread 18-01-2011, 13:13
Bot190's Avatar
Bot190 Bot190 is offline
FRC #0166 (ChopShop)
Bot190 will become famous soon enough
Re: WPI Library RobotDrive::HolonomicDrive
Looking at the Source, Magnitude and Rotation are -1.00 ... 1.00 values. It doesn't give a unit for direction, although looking at the code it seems to be in degrees.
The source is included in a zip in the update, I have uploaded it here if you don't want to run the updater.
[edit]Updated url to point to latest version
Unread 18-01-2011, 13:20
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Latest versions also available on FIRST Forge (requires registration - free), http://firstforge.wpi.edu/sf/projects/wpilib
Unread 18-01-2011, 13:34
Bot190's Avatar
Just like to point out that the code on source forge right now is not up-to-date, and won't always be up-to-date.
Unread 18-01-2011, 13:40
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
Umm...Ben?
You uploaded revision 2222's code.
The update for this year's 2242.
GSR Dean's List Finalist 2011
Unread 18-01-2011, 14:19
answers so far underlined. still seeking answers to items in red:
1) magnitude. -1 to +1 unitless ?
2a) direction units. degrees ?
2b) direction range (ie 0..360 or +/-180 etc) ?
2c) direction: where is zero ?
2d) direction: CW or CCW?
3a) rotation rate range. -1 to +1 unitless ?
3b) rotation rate: positive CW or CCW?
