Go to Post It's OK to make some mistakes, as long as you learn from them. - Doug G [more]
Unread 18-01-2011, 14:32
Re: Cypress Tutorial?
Look at the back of the Cypress board and you'll see the pins labeled that you wire your swiches and potentiometers to:
http://www.chiefdelphi.com/forums/at...2&d=1264090529
Wirewrap, a prototype board, or purchasing a special mount from AndyMark can be used to connect your switches.
There's no programming necessary on the Cypress or Driver Station.
If you look on the Driver Station I/O tab you can see if it's working and even change some of the characteristics of how each contact is handled.
In LabVIEW you check your switch settings using:
  • Driver Station Get Digital Input
  • Driver Station Get Analog Input
You'll find them on the block diagram pallete at: WPI Robotics Library -> Driver Station -> Compatibility IO
