Go to Post Not joining as a freshman was the worst mistake I have ever made. - ProgramLuke [more]
Unread 13-01-2011, 21:27
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Tetrix DC Drive Motor W739083 dynamometer data
I got some of the W739083 Tetrix motors (12V, 152 RPM marking) to test in my lab. We performed dynamometer tests to measure the output mechanical power vs. torque, for two types of electrical source: (1) a regulated 12V laboratory bench supply, and (2) a standard 12V (marked) W739057 Tetrix NiMH battery pack. We did not measure the battery voltage; however, the (unloaded) initial motor speed when fed from the battery probably indicates variation of its voltage due to the previous test. Some charging was done between tests.
We repeated the power curve measurements for four sample motors. Three showed consistent performance, and one was slightly lower. Results follow:
With regulated 12V dc supply:
Motor 1: 10.8 Watts peak output mechanical power at ~75 RPM, 145 RPM initial motor speed
Motor 2: 10.8 Watts peak output mechanical power at ~75 RPM, 145 RPM initial motor speed
Motor 3: 10.1 Watts peak output mechanical power at ~75 RPM, 143 RPM initial motor speed
Motor 4: 10.9 Watts peak output mechanical power at ~75 RPM, 148 RPM initial motor speed
With Tetrix battery: (voltage > 14V)
Motor 1: 16.5 Watts peak output mechanical power at ~90 RPM, 178 RPM initial motor speed
Motor 2: 16.0 Watts peak output mechanical power at ~90 RPM, 173 RPM initial motor speed
Motor 3: 14.2 Watts peak output mechanical power at ~90 RPM, 172 RPM initial motor speed
Motor 4: 15.2 Watts peak output mechanical power at ~90 RPM, 176 RPM initial motor speed
Based on the above, my calculations for climbing time and gear ratio would yield a recommendation for 4" wheels and 2:1 gearing, for a (theoretical) climbing time of about 3 sec if we assume the minibot mass is 5 lb, two motors are used, and the mechanical efficiency (motor shafts to pole) is 75%. That mechanical efficiency might be about right, considering that my dynomometer measurements did not include any side loading on the motor shaft, which will certainly be present in the minibot.
Of course your motors may vary from the ones we tested. However, two general conclusions are still valid:
(1) Battery state of charge will be a very significant factor for minimizing climbing time. So will mechanical losses in the power train from motor shafts to pole.
(2) Design calculations based on the published motor data are likely to be too conservative; my calculations using the published data would yield a recommendation for 3" wheels, while the test data above suggests that 4" wheels are a better choice.
NOTE: I wanted to include the raw data and plots of speed and power vs. torque; however, they cannot be attached to this post because the file size is too large (>101.8 kB).
Test Temperature: Ambient (22 degrees C)
Software: M-Test 5.0
Dynamometer: Magtrol HD 705-6N (Calibrated 01/12/2011 by NT)
Dyno Controller: Magtrol 4629B (ML144)
Power Supply: Sorensen XG 150-11.2
Richard Wallace
since 2003
Unread 13-01-2011, 21:37
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Re: Tetrix DC Drive Motor W739083 dynamometer data
Nice !
Thanks Richard for doing this test and sharing.
Ed Sparks
MECH TECH FRC-3959
Unread 13-01-2011, 21:54
REVving up for a new season
FRC #2848 (All-sparks)
Thanks for the testing Richard.
For reference here are the published specs for the motor as taken from the PTC curriculum which uses tetrix.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 13-01-2011, 21:58
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
3 seconds seems about right. We have 2 separate designs that travel up the pole between 2.7 sec and 3.1 sec. (depending on who is running the stopwatch)
My initial calculations stated that we could make it up in a little less than 3 seconds, so it seems that the JVN Calculator was accurate.
So, summary
4lbs bot
2:1 gear ratio
2.7 second climb time
Unread 13-01-2011, 23:42
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Like Richard, I too live for the details. Thank you Richard for stepping up to gather and provide this information for all teams. You really have a full grasp on the spirit of this competition.
Unread 14-01-2011, 01:00
LH Machinist LH Machinist is offline
LH Machinist has a spectacular aura aboutLH Machinist has a spectacular aura aboutLH Machinist has a spectacular aura about
Thanks for the information. However, it doesn't make sense in my mechanical mind...using a 2 to 1 gear reduction with 4" wheels. An unloaded motor runs @ 178 RPM, (2.96 revolutions second) multiplying this by the circumference of a 4" wheel. 2.96 x 12.56 = 37.17 inches per second. Based upon the math and considering the load will reduce RPM, +/- 3 seconds is plausible.
If the RPM is reduced by 1/2. +/- 6 seconds seems like the time to reach the top.
Am I missing something?
Unread 14-01-2011, 05:18
Originally Posted by LH Machinist View Post
Thanks for the information. However, it doesn't make sense in my mechanical mind...using a 2 to 1 gear reduction with 4" wheels. ... Am I missing something?
Sorry, I should have expressed that a little more clearly.
I meant a 2:1 speed INCREASE from motor shaft to wheel. Effectively making a 4" wheel behave like an 8" wheel mounted directly on the motor shaft.
Here's how I did the math:
Climb height = 110 inch (2.79 meter)
Energy = height X weight = height X mass X g
Energy (Joule) = height (meter) X mass (kg) X 9.8 m/sec^2
Example: if mass is 5 lb (2.27 kg) then energy = 62.2 Joule
Maximum motor output power (assuming a full Tetrix battery) is about 15 Watt at 90 RPM -- operating at different RPM will REDUCE the power.
Time to climb = Energy / Climbing Power
Climbing Power = Motor Power X drivetrain efficiency
If drivetrain efficiency is 75% and two motors are used, then Climbing Power is 30 X .75 = 22.5 Watt. So, Time to Climb is 62.2 / 22.5 = 2.8 seconds, and climbing speed is 110 inch / 2.8 sec = 39.8 inch/sec. If 4 inch diameter wheels are used, then wheel speed is 39.8 / 4*pi = 3.2 rev/sec = 190 RPM. To match this wheel speed to the 90 RPM motor speed, the gear ratio is 190/90 or ~2.
Richard Wallace
since 2003
Unread 14-01-2011, 09:02
boomergeek's Avatar
boomergeek boomergeek is offline
AKA: Mr. D (Dick DiPasquale)
FRC #0241 (Pinkerton Robotics)
boomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant future
Great information on motors/drivetrain for the minibot! Thanks!
Some rough analysis by FIRST Team 241 of the video at the Kickoff: The running bot seemed to have:
1) direct drive
2) 3" wheels
3) two motors
It also seemed to climb the entire length of the tower in just under 5 seconds.
That would seem to imply PI*3" per revolution = 9.4" or 12-13 revolutions in 5 seconds or about 144 RPM under load of the minibot.
We don't have the ftc-020 First Choice kit yet and the abbreviated list of parts does not detail the wheels included. I see a grainy picture associated with the kit but I really could not make out 4" wheels.
We plan to run experiments as soon as we get the kit. Hopefully we will get them soon.
Unread 14-01-2011, 10:10
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Thanks for the data Richard!
4"x1:1 versus 3"x1:2
(4"x1:1 is a 4" wheel with a 1:1 ratio, direct driven; 3"x1:2 is a 3" wheel with a 80T gear on the motor and a 40T gear on the wheel)
Since mass will affect every race, is the added mass to get a 1:2 gearing on a 3" wheel worth the complexity versus a direct drive 4" wheel? I don't think so. My charts show that a 3"x1:2 is only 0.1 seconds faster than a 4"x1:1 since adding gears adds weight (gear mounting, extra axle primarily). I'd suggest trying it with both and seeing what you gain from the flexibility in the design from 4"x1:1.
Edit -- Whoops -- the calculator didn't factor in another efficiency drop due to the extra gears -- so now 3"x2:1 is just on par with 4"x1:1.
GitHub
Unread 18-01-2011, 13:52
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
so from what I see everyone is planning on a tall gear ratio (to theoretically increase wheel diameter)
I am very uneducated on electrical motor performance but so far I thought Max performance was somewhere near the motors free speed (although I do understand you get full torque at any RPM assuming your motor does not burn up) if this was the case wouldn't you want a shorter ratio than 1:1 essentially creating a slower and higher torque drivetrain to ensure the motor was operating at peak RPM.
I'm pretty sure I'm wrong based on Richard statements
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 18-01-2011, 14:10
Colin -
You are likely thinking of a different type of motor. Maybe an internal combustion engine?* DC motors behave very very differently.
Take a look at the spec Greg posted, it will clear things up.
For a given voltage, a DC motor has the most Power output at about half of its free speed. Torque is highest at stall, and decreases linearly to zero torque at free speed.
* My knowledge of combustion engines is pretty close to zero, but I think wenkels have performance like you suggest: http://4wings.com.phtemp.com/crafts/a2con/torque.jpg
Unread 18-01-2011, 14:37
human
AKA: Colin Nobles
FRC #0148
after looking at the graphs for the thousand time I sort of understand how to read them I see that maximum efficiency at 88 RPMs
I had the idea about Max torque at zero RPMs from electric dragsters
But I guess that doesn't translate maybe brushless motors?
Anyhow I'll gear it to hopefully bog to 88 RPMs
Thanks for all help folks just goes to show 20 years of school rarely matches up to simply asking a question and accepting that you are clueless in the subject.
ps Wankel's are awesome i Have a snowmobile with one
Originally Posted by Richard View Post
Wow, thanks Richard!
Could you please post a little info on how you got the data? I might make a few freshman recreate this data.
Also, would you mind emailing me the raw data?
Unread 20-01-2011, 01:28
Dr Fritz's Avatar
Dr Fritz Dr Fritz is offline
AKA: Fritzelin
FRC #1165 (Team Paridise)
Dr Fritz has a spectacular aura aboutDr Fritz has a spectacular aura aboutDr Fritz has a spectacular aura about
Great work. thanks for the test and info
ph.D Asskickanomics
Magnets work well
Thor Protector of Man kind
Raise your swords up high
See the black birds fly
Let them hear your rage
Show no fear
"Our Mini-bot goes 'clink-whee"
Unread 21-01-2011, 12:30
Some folks here on CD have asked for a bit more data, so I am adding it here.
We used another of our dynamometers to measure mechanical output and efficiency for two of the Textric DC Drive motors (units 2 and 3 from the original post), with their gearheads removed. This gives some insight to the electrical and mechanical power losses.
At 12V dc, these two motors developed peak shaft powers ~ 17.6 and 15.8 Watts, respectively -- this is about 7 Watts more than was measured when the motors were tested with gearheads. That difference is the mechanical power loss in the gearhead, at peak loading.
Also, at peak shaft powers these two motors showed electromechanical efficiencies ~ 45% and 40%, respectively. In other words, motor 2 consumed 17.6 / 0.45 = 39 Watts, and motor 3 consumed 15.8 / 0.4 = 39.5 Watts, from the 12V dc supply. So motor 2 wasted 39 - 17.6 = 21.4 Watts, and motor 3 wasted 39.5 - 15.8 = 23.7 Watts, due to heating of their respective armature windings. These are the motors' electrical losses.
My conclusion -- teams might gain an advantage in climbing power by replacing the gearheads on these motors with more mechanically efficient alternatives, but the potential benefit is probably only a few Watts (my guess is 2 to 4 Watts). The time a team would spend refitting Tetrix motors with more efficient gearheads is probably better spent working on faster minibot deployment methods.
Richard Wallace
since 2003
