Go to Post I'm sure there aren't a bunch of rule makers sitting in a board room discussing "What rule can we change now to mess with the teams' heads?" Lets all just sit back and enjoy the regionals! - Rick [more]
  #31   Spotlight this post!
Unread 18-01-2011, 14:42
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Re: RS775 Gearboxes
Originally Posted by Alienvin View Post
RS775 18V Motors...... Before jumping to the motor with the larger number, check out the Motor Specs to each of the available Motors. In my eyes, that RS550 Motor in most ways is superior and now one of our fellow FIRST Team members spoke to Banebots this morning about the Availability of the different versions of the gearboxes for the RS775 Motor..... More options going with the lower motor. Plus more Torque.
Which specs are you looking at when comparing those two motors? I see two conflicting sets of numbers when I look at the motor curves on the KOP website and then compare to the yellow BaneBots Motors page from the kit. The motor curves give lower numbers than the BaneBots sheet. Here is what that sheet lists for RS-775:
No Load: 13000 RPM, 1.8 A
Peak Efficiency: 119 W, 11360 RPM, 12.5 A, 14.2 oz-in.
Stall: 86.7 A, 110.8 oz-in.
Then you go to the site listed on the yellow sheet, www.banebots.com/M7-RS775-18, and you find a third set of numbers.
Does anybody know which numbers are right? The motor curve on FIRST seems wrong.
