Go to Post FIRST for me is getting to opportunity to learn from the smartest people I know, the mentors. - faust1706 [more]
  #31   Spotlight this post!
Unread 18-01-2011, 12:11
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: RS775 Gearboxes
Originally Posted by sanddrag View Post
On the BaneBots page, it says they'll be offering a 64:1 and a 256:1 for the 775. Really? Nothing in between those ratios?
What Tom said. Looks like they're initially only offering the 4:1 stages for the RS-775s. If the RS775 4:1 stages are identical to the RS-540 4:1 stages, then you could buy some of the 5:1 stages from the P60 Gearbox Parts pages and swap them in to make up your own ratios. I suspect they're not going to have a 5:1 pinion for the motor itself, so you'd be swapping in at the 2nd stage or later, which is a little less than ideal... But you'd still get the different ratios you're looking for. 4:5:4 = 81:1, 4:5:5 = 103:1, which gives you a few more options between 64 and 256. Granted that you still have the big jump up from 103 to 256, but unless BB comes out with some 3:1 stages, that's always gonna be a sizable jump.
  #32   Spotlight this post!
Unread 18-01-2011, 14:12
Alienvin's Avatar
Alienvin Alienvin is offline
Technically Speaking, Who Knows....
AKA: Vinny
FRC #1546 (Chaos Inc.)
Alienvin is an unknown quantity at this point
Re: RS775 Gearboxes
RS775 18V Motors...... Before jumping to the motor with the larger number, check out the Motor Specs to each of the available Motors. In my eyes, that RS550 Motor in most ways is superior and now one of our fellow FIRST Team members spoke to Banebots this morning about the Availability of the different versions of the gearboxes for the RS775 Motor..... More options going with the lower motor. Plus more Torque.
2010 Regional Finalist Award Winner - SBPLI Long Island Regional
2007 Kleiner Perkins Caufield & Byers Entrepreneurship Award Winner - SBPLI Long Island Regional
2006 Johnson & Johnson Sportsmanship Award Winner - SBPLI Long Island Regional
2005 Rookie All-Star Team Award Winner - SBPLI Long Island Regional
http://teacher.baldwinschools.org/robotics
  #33   Spotlight this post!
Unread 18-01-2011, 14:34
Aren Siekmeier's Avatar
on walkabout
Re: RS775 Gearboxes
Can you explain what you mean by this? From the specs I have, it looks like the RS 550 outputs 21 fewer Watts at peak power (266W vs. 245W). To me, this is strictly inferior (although not by much). Is there some other factor you are taking into account? I have also heard that because the motor is designed for 18V, it runs more reliably at 12.
We are considering using one RS 775 for each of the strafing wheels in our holonomic drivetrain. Will the load from a drivetrain be too much for these motors and the gearboxes on them? There seems to be some concern about max output torque. Would the RS 550 be a comparable alternative, in light of the greater availability of those gearboxes?
  #34   Spotlight this post!
Unread 18-01-2011, 14:35
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Re: RS775 Gearboxes
Plus more likely to catch fire under stall load!
I'll stick to the 775's and their greater robustness...
  #35   Spotlight this post!
Unread 18-01-2011, 14:42
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Re: RS775 Gearboxes
Which specs are you looking at when comparing those two motors? I see two conflicting sets of numbers when I look at the motor curves on the KOP website and then compare to the yellow BaneBots Motors page from the kit. The motor curves give lower numbers than the BaneBots sheet. Here is what that sheet lists for RS-775:
No Load: 13000 RPM, 1.8 A
Peak Efficiency: 119 W, 11360 RPM, 12.5 A, 14.2 oz-in.
Stall: 86.7 A, 110.8 oz-in.
Then you go to the site listed on the yellow sheet, www.banebots.com/M7-RS775-18, and you find a third set of numbers.
Does anybody know which numbers are right? The motor curve on FIRST seems wrong.
  #36   Spotlight this post!
Unread 18-01-2011, 14:46
Re: RS775 Gearboxes
Seconded! RS-550's and FP's fail spectacularly under heavy loads. For the uninitiated, these motors have nice little plastic impeller fans to blow air across the coils and cool them. But the more you load them, the slower they turn, the hotter they get... This continues for a short while till you melt the little plastic fan. At that point, the motor's toast because it'll never be able to adequately cool itself. And that's assuming it hasn't managed to catch fire or short itself out before the breaker trips.
  #37   Spotlight this post!
on walkabout
Re: RS775 Gearboxes
I am using the numbers from the Banebots site for the 18V motor, then bringing them down according to the Voltage difference, giving the performance at 12V.
These are:
Free Speed - 13000 rpm
Stall Torque - .7833 Nm
Stall Current - 86.67 A
Free Current - 1.8 A
for the 18V RS 775 running at 12V.
  #38   Spotlight this post!
Unread 18-01-2011, 14:47
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Re: RS775 Gearboxes
There was another thread about this, and banebots posted some official numbers for all the KOP motors, including the 775-18 running at 12V.
P60 with RS775, P80 with RS775 and CIM-U-LATOR should be up on the web site by the end of the week and available for order at the start of next week.
Links to data sheets for the BaneBots motors found in the KOP:
http://banebots.com/docs/M7-RS775-18-AT12V.pdf
http://banebots.com/docs/M5-RS550-12.pdf
http://banebots.com/docs/M5-RS540-12.pdf
http://banebots.com/docs/M3-RS395-12.pdf
Note the RS775 data sheet is for the 18V motor in the KOP at 12V
BaneBots
  #39   Spotlight this post!
Unread 18-01-2011, 14:48
Re: RS775 Gearboxes
FIRST used the numbers for a different BB RS-775 motor that's specifically a 12V motor. The correct numbers and curve were posted by BB in a different thread:
  #40   Spotlight this post!
Unread 18-01-2011, 15:28
Racer26 Racer26 is offline
Re: RS775 Gearboxes
Originally Posted by iCurtis View Post
<snip>There are a lot of great teams in 2007 that didn't actuate at anything close to 180 degrees/second. There probably are some that did too</snip>
In 2007, 1075 built a multi-position pneumatically powered arm (a single cylinder drove it, under control of 3 air valves [supply valve, exhaust valve, and direction valve]) It was able to stop anywhere in its travel, and used PID control to stop where we wanted it to (at the three heights, plus the floor) using a potentiometer. It was FAST. I would not be at all surprised if it approached 180deg/sec. It never seemed in danger of tearing the robot apart, to me at least.
It did however have PID issues where it would oscillate around the set point occasionally, particularly if air pressure fell below 60psi and the valves stopped operating consistently.
It was a much-improved derivative of our 2004 off-season arm, which was also multi-position pneumatic, (and as far as I know, one of the earliest examples of multi-position pneumatics using KOP valves in FRC [at the time, you were restricted to using the valves that came in the KOP, which were standard single and double solenoid valves, without an 3rd setting to stop the cylinder])
  #41   Spotlight this post!
Unread 19-01-2011, 01:49
Carter12s's Avatar
Carter12s Carter12s is offline
Team Cap
FRC #3374 (Robo-Broncs)
Carter12s is just really niceCarter12s is just really niceCarter12s is just really niceCarter12s is just really nice
Re: RS775 Gearboxes
My calculations show a 5 kg arm about 60" long with the weight distributed about 80% of the way down the length of the arm to be able to move 120 degrees in under 5 seconds with a single RS-775 and a 256 to 1 gear ratio. I was pretty careful, but these may be slightly off.
Programing is the real way to build a robot.
  #42   Spotlight this post!
Unread 19-01-2011, 02:08
Chris is me's Avatar
AKA: Pinecone
Re: RS775 Gearboxes
It is.
  #43   Spotlight this post!
Unread 19-01-2011, 08:07
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: RS775 Gearboxes
I don't know if anyone's seen this yet, but it appears that P60's for the RS-775 are now available for purchase via Banebot's website: http://banebots.com/c/P60K-S7
Nothing like delaying a product release and then saying there's a 5-10 day lead time...
-Dustin Benedict
  #44   Spotlight this post!
Unread 19-01-2011, 08:53
Brandon Holley's Avatar
Re: RS775 Gearboxes
Pretty frustrating to say the least.
We weren't planning on using the banebots gearboxes, but we have the means to help ourselves out on that front. I feel for teams that will be relying on banebots to interface with their motors. Having to wait 2 entire weeks (10 buisness days) for your gearboxes to arrive could be devastating.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
  #45   Spotlight this post!
Unread 19-01-2011, 14:10
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Re: RS775 Gearboxes
Why subject your robot to a potential sensor failure when you can train a monkey (or a student, if monkeys are lacking) to put the tube at the right height every time?
Humans fail far more often than sensors. Plus, humans react on the order of a few thousand times greater than a sensor.
Attending: MN Duluth Regional
