Go to Post So, in the good old FIRST spirit, let's all start brainstorming and sharing ideas, ok? :D - LauraN [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 16-01-2011, 19:22
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
CAN on a budget
after my experiences working on getting can to work on my team in the last few months, i decided to make a .pdf on how to make CAN work this year without killing the piggy bank.
I attached it.
comments?
Unread 16-01-2011, 21:41
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: CAN on a budget
Thank You for this, I was just researching the best way to go about using the CAN bus. Might I suggest you post this to the whitepapers as well.
Unread 16-01-2011, 22:14
ratdude747's Avatar
AKA: Larry Bolan
Re: CAN on a budget
i want to do some last proofreading and editing first... once fully polished, it will be headed there.
good luck with you CAN experience!
edit- updated file attached. it will be sent to the whitepapers as well.
Unread 16-01-2011, 23:47
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: CAN on a budget
Nice paper.
One point of fact that you may want to look into, there are more than 2 FIRST 'Legal' options for CAN. A team could also make their own gateway device using either Ethernet or serial.
Good job.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 17-01-2011, 00:00
ratdude747's Avatar
AKA: Larry Bolan
Re: CAN on a budget
Originally Posted by Mike Copioli View Post
Nice paper.
Good job.
I was not aware of that. I will research it further.
It has been added as a white paper and i have updated it (attached). It also has a section on how to use a junk serial cable to make the serial adapter (essentially how i made the 2009 KOP cable to work in the first place).
Edit- yes, you can make your own adapter. good call. updated file attached.
Unread 18-01-2011, 16:11
ratdude747's Avatar
AKA: Larry Bolan
Re: CAN on a budget
lots more original pictures have been added
the new version is at http://www.chiefdelphi.com/media/papers/2433
enjoy!
