Go to Post If you water it and nurture it and fertilize it and put it out in the sunlight, it might just grow up to be a big lathe... :) - dlavery [more]
Unread 01-18-2011, 08:11 PM
linuxboy linuxboy is online now
AKA: Oliver Graff
FRC #3780
linuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud of
Sending IO data to the dash
Hi,
Simple question that can probably be answered easily (I searched and couldn't find an answer so it must be reaaaaly simple) but the GPIO, PWM, and other data is not showing up on the dashboard but the camera is (after a call to AxisCamer::GetInstance()). How do I send that to the classmate? My programming env. is LabView and the Dashboard im using is the one that comes in the wizard in labview which != the one that comes on the classmate image but it is similar.
Thanks,
Oliver
