Go to Post You know you're addicted to FIRST when...you realize that Dean IS changing society with FIRST and you love the fact that you are helping. - EStokely [more]
Unread 01-18-2011, 08:10 PM
ahudson ahudson is offline
FRC #3179
ahudson is infamous around these parts
Question Robot Code
I had a good connection with my robot while tethered, but when I tried to go wireless it said there was no Robot Code. When I tried to go back to tethered it still said there was no Robot Code. Please help diagnose our problem.
Unread 01-18-2011, 08:18 PM
~Cory~'s Avatar
~Cory~ ~Cory~ is offline
Student
AKA: Cory Rypkema
FRC #0706
~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold
Re: Robot Code
First, can you ping 10.x.x.1 (with xx being your respective team), 10.x.x.2 and 10.x.x.4 ?
As silly as this sounds, make sure everything is plugged in. Then rebot the crio and download code.
corin.rypkema.org
WPI Class of '17
'12 Dean's List Finalist, Mentor of 706 - Cyberhawks
Unread 01-18-2011, 08:27 PM
FRC #3179
Re: Robot Code
How do you ping?
Unread 01-19-2011, 12:33 AM
Re: Robot Code
At a command prompt, simply type the command.
ping 10.31.79.1
Unread 01-19-2011, 09:34 AM
Re: Robot Code
If the Driver Station Communication light is green, but the Robot code light is red, then it isn't a communication problem. Both wireless & tethered are doing their job correctly.
Check the other DS statuses under the Diagnostics tab to see what the Driver Station can ping. Green = successful pings are happening all the time.
If Communication is good, then look at your code deployment.
Unread 01-19-2011, 02:10 PM
FRC #3179
Re: Robot Code
Ok when I try to run as start up it says the real time target has not been built Also it says the Lab view Vi's are in evaluation mode
Unread 01-19-2011, 03:52 PM
Re: Robot Code
You need to activate your installation of LabVIEW to get out of "Evaluation mode"
You can do that through Start -> National Instruments -> NI License Manager
You need to be connected to the Internet.
In the License Manager look for a half yellow box. A little popup "Activate..." to click on will appear if you mouse over it.
Here's a picture showing you where to find Build.
http://www.chiefdelphi.com/forums/at...1&d=1295370058
You "Build" first, then you "Run as startup" to put it permanently onto the robot.
