Go to Post Life is too short to spend 40 hours a week doing something you are not enthusiastic about. - Karthik [more]
Unread 16-01-2011, 11:50
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
LabVIEW Encoder not reliably returning Rate
Hello, all.
Yesterday, I was testing and tuning some code on a test chassis. It has two Toughboxes and US Digital encoders (from AndyMark, 250 count) connected to the last four digital inputs on the Digital Sidecar. In code, I found that Encoder Get does not reliably return Rate: I always get Distance (which I found to be accurate in both forward and reverse, by drawing a line on the wheel and reading the distance both ways. Only one of the encoders returns rate, though, which puzzles me. What puzzles me even more is that when I set the Decoding Type to 4x (Because that uses an FPGA Encoder instead of an FPGA Counter) it works - but only until I reboot (when the problem happens again, and is fixed by switching back to 1x).
I dug into the WPI Encoder Get to see if there was a bug there. WPI Counter Get is returning a time of Inf, which Encoder Get is scaling to 0. I went into WPI Counter Get, but that just talks to the FPGA (meaning I cannot dig deeper). When I first had the issue, I probed the Dev Refs and the non-working encoder was using Cntr 1 while the working encoder was using Cntr 0. I did not probe them using the 4x decoding, but when using 4x decoding, the other side (the one that worked before) now has the issue.
I am sure all of the hardware works. I swapped the encoder wires (Between encoders) and the problem is not the encoder itself. I also know that I am not missing the B-phase, because it counts forwards and backwards. Everything I have looked at points to a bug in the FPGA encoder handling, I am using the latest 2011 image. (I guess I could try the 2010 image to see if it works, but I won't have access to the robot until Monday).
Has anyone seen this issue? How did you solve it?
Kettering Motorsports
Unread 16-01-2011, 21:06
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Re: LabVIEW Encoder not reliably returning Rate
We had a similar issue in Java.
We had one returning a reasonably rate and a second encoder that was returning essentially garbage. We spent an hour debugging, swapping connectors and twiddling without any success.
We eventually just wrote our own rate functions and moved on.
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 16-01-2011, 22:19
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
We also noticed the encoder rate not working when using 4x decoding and also found the problem coming from the counter returning a time of Inf. The rate returned a value of 0. We changed the decoding to 2x and began receiving rate data.
Unread 17-01-2011, 01:09
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Originally Posted by apalrd View Post
Hello, all.
I'm really curious if the same issue reproduces in any other language. There have been a few issues with the encoder rates in the past, but I had thought we fixed them all.
Have you tried modifying the averaging settings? How does that setting impact the behavior? Is there any interaction between the 2 resources... i.e. if you make one encoder 4X and the other 2X, does it still do this?
Thanks,
-Joe
<edit>I assume you are using v25 since that is the only non-beta 2011 image</edit>
Unread 17-01-2011, 12:38
lon.bushweiler lon.bushweiler is offline
FRC #0093
lon.bushweiler is an unknown quantity at this point
We ran into similar issues in Labview over the weekend. Like others, we wrote our own rate code and moved on.
Unread 18-01-2011, 20:49
nchen99 nchen99 is offline
AKA: Nelson Chen
nchen99 is an unknown quantity at this point
Today we tested the 9 possible resolution combinations of our two encoders, which we'll call Left and Right. When still, the encoder rates both return 0.0; when moving, the non-working one returns NaN (Not a Number). Here are the results:
Y = Yes/returned decimal value
N = No/returned NaN
Format:
LeftResolution, RightResolution: LeftResult, RightResult
4, 4: N, Y
2, 4: Y, N
1, 4: Y, N
4, 2: N, Y
2, 2: Y, N
1, 2: Y, N
4, 1: N, Y
2, 1: Y, N
1, 1: Y, N
Unread 19-01-2011, 08:27
apalrd's Avatar
More Torque!
VRC #3333
I did some testing last night:
I found that, after booting up the robot as flashed (1x, 1x) it worked fine for about 2 hours, only rebooting once to change the battery.
After it stopped working, nothing would fix it. Nothing. I rebooted several times and re-downloaded the code. I set the counter to average 2 samples, as advised in this thread, and it worked.
I didn't spend a whole lot of time testing, so I don't know if the problem will re-appear after use. I will try tonight.
Unread 19-01-2011, 23:33
apalrd's Avatar
More Torque!
VRC #3333
More testing today (about 3 hours or so):
1. The encoder does not work, even averaging 4 samples (only 1 side dosen't work, the other one is fine).
2. After getting it to work, it worked reliably for about an hour before quitting. Then, after changing some settings (like the decoding type) and rebooting, it worked again (and didn't quit while I was working on it)
3. It seems very random, yet always affects the same side. Has anyone from NI been able to reproduce this problem?
4. I am running image v.25
Unread 25-01-2011, 15:49
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
I have reproduced this and believe it is a bug in our code. I suspect we may document this rather than fix it for this season for two reasons:
1. It would be a risky fix.
2. There is the work around of writing your own rate code.
Doug Norman
Unread 31-01-2011, 17:54
cabbagekid2 cabbagekid2 is offline
#0368 (Kika Mana)
cabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura about
We just got started with the encoders that came in the KOP and are running into the same issue as everyone else. Our right side has both rate and distance but the left side only shows distance (rate is 0).
We're going to write our own rate code and was wondering...since distance works for both sides if it's as simple as storing the present distance into a variable and subtracting the saved (previous present distance) from the prsent distance. This will be in periodic task...so that you can divide it by the loop time interval to obtain rate.
We tried this for our working side and came up with similar results as the encoder rate output and are hoping to get it working on the left side.
One thing we noticed though (both with our rate and the VI rate) is that it's REALLY noisy. When maxing out the joystick it bounces around anywhere from zero to 250 rpm (low gear). We had to up the sample average (which cleaned it up a little) and then added a point by point median filter. The only thing bad about this is that the filtered rate is only 100 rpm (can you imagine the noise to produce this!).
Anyone else have noise issues? We're still not sure if the rate data will be workable after all this filtering. More testing today...
Might also be the placement of our wires...will test that today too.
Unread 31-01-2011, 18:40
One thing that was discovered is that every other encoder works... so if you allocate one and ignore it and then allocate another one, you can use the built-in rate function. Naturally this means you have half as many that you can use, but if you don't need that many, this may be a good solution for you.
-Joe
Unread 01-02-2011, 14:02
IisMathwizard's Avatar
IisMathwizard IisMathwizard is offline
Programming Mentor
AKA: Mathwizard
FRC #1248 (Titanium Allies)
IisMathwizard is an unknown quantity at this point
We've also had a problem witho our encoder. At first it was working well and i then went on to do some calibration with distance but after about 5 runs of calibration it was then only producing the values 0 and the resolution of .0038..... something. We looked through my coding and found nothing wrong and then assumed hardware issued. Nothing was apparently wrong and we left the issue for later. Unfortunetly, someone wasn't looking and ripped the wiring right out of the encoder. Nonetheless, it died. We reinstalled it but hadn't wired it up again and tried calibration.
jRIO 2013 Project
Unread 03-02-2011, 19:10
So, was there ever a fix for this?
Unread 03-02-2011, 19:40
Sorry. This was deemed not critical enough to fix in the middle of build season by Management. Fortunately there are 2 workarounds... implement the rate calculations yourself (high CPU burden and less accurate) or construct twice as many encoders as you need and only use the even ones (you can only decode half as many).
-Joe
Unread 04-02-2011, 12:11
-Joe
Can we create these on an unused DIO slot? Unused IO pins on the one DSC we have are hard to come by.
