Go to Post Winning just makes your ego smile. - MooreteP [more]
  #31   Spotlight this post!
Unread 18-01-2011, 09:12
Brandon Holley's Avatar
Re: Are extensions with bumpers after the start of the game legal
Originally Posted by pfreivald View Post
It's a neat idea, but I just don't see it working in terms of "high speed offensive bot ramming the edge of yours"-type contact. 150 lbs of robot at 11+fps hitting the extended edge of a 42" moment arm = more torque than I can imagine any robot that can't grip the carpet (as no robot can) can handle.
Maybe I'm wrong. I've been wrong before -- very wrong -- when it comes to robot capability and any given FIRST game.
MOE, Team 365 from 2002 comes to mind when thinking about something like this. Given, back then you could have metal dig into the carpet, but MOE had a system that would expand the entire width of the field more or less and was able to stay in place/move forward much of the time.
Originally Posted by iCurtis View Post
Just thought of something. Depending on the GDC's interpretation, you may have a sticking point with <R09>. As others have established, your external bumpers are not BUMPERS, so they wouldn't count as acceptable places to put your numbers. If the flaps are down, they may say that your team numbers on the BUMPERS covered by the flaps are not clearly visible. If you ask the Q&A be sure to do so in very general terms, as if you get too specific they typically say "we cannot comment on a design."
A valid concern, but I imagine MANY teams manipulators they are using to pick up tubes will present the same issue.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
  #32   Spotlight this post!
Unread 18-01-2011, 14:14
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Fun times. You'll fit right in.
  #33   Spotlight this post!
Unread 18-01-2011, 15:38
TEE's Avatar
TEE TEE is offline
FRC #0201
TEE has a spectacular aura aboutTEE has a spectacular aura aboutTEE has a spectacular aura about
Originally Posted by Nathan Streeter View Post
I actually disagree with the suggestion of using the roughtop "stomp pad." I think the ability to drive side to side would be more valuable/better than an articulating stomp pad...
You're right.
@Original Post
Wheels (a lot of them) on their own should be able to give as much traction as a stomp pad, but the main idea is to get most to all of the weight onto the bumper extensions.
Also, it would be beneficial (if you plan on deploying a minibot, or if you get pushed out of position) to raise the bumper extensions, because the long configuration being won't be very maneuverable when it comes to turning.
  #34   Spotlight this post!
Unread 18-01-2011, 15:46
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
However, if you choose to deploy this between your towers. You will presumably never have to turn again the entire match. Then to deploy the mini-bot you just bump into the tower and go from there.
Also, I would consider creating an auto mode which gets right up to the middle line so you can deploy as soon as possible.
My favovite thing about this stratigy is that not only will you be blocking teams out of their scoring area. You will also be traping teams inside the area. The more I think about it the more I like it. This is definatly the best possible defensive stratigy for the game this year.
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
  #35   Spotlight this post!
Unread 18-01-2011, 15:50
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
Yup. When we discussed this strategy that was one of it's biggest advantages. Not only did they have to fight their way through you to get to the scoring rack, you better believe they are also going to have to fight you to get out.
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
  #36   Spotlight this post!
Unread 18-01-2011, 15:59
BJC's Avatar
BJC BJC is offline
AKA: Bryan Culver
27 X 54 ft field.
27x12= 324in
field lanes= 4ft 4x12= 48
half tower base= 15in
robot length= 82 in
324-48-48-15-15-82= 116 in
116/2= 58 inches on either side of you when in the middle of the field.
58/12= 4.8333 ft
you must be able to travel about 9 fps to be effective with this stratigy.
  #37   Spotlight this post!
Unread 18-01-2011, 20:20
RyanCahoon's Avatar
RyanCahoon RyanCahoon is online now
FRC #0766 (M-A Bears)
Possible countering strategy: one robot stays on the scoring zone-side of the dragonfly, the other two acting as feeder robots, that pass tubes over the dragonfly. This has been talked about a lot anyway, but against the dragonfly seems to be the place where it would be most effective. Makes a good argument for multi-joint arms and/or a small "kicker."
--Ryan
FRC 766, 2015-, Mentor
  #38   Spotlight this post!
Unread 18-01-2011, 21:37
staplemonx's Avatar
staplemonx staplemonx is offline
The Idea Guy
AKA: JJ Biel-Goebel
FRC #1389 (The Body Electric)
staplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond repute
Thanks for all of the feedback. The team went through them today and changed a few things in our design. I will get them loaded up here in a few days.
We are going to reduce the size our extension width to eliminate any overhang of the perimeter in our starting configuration
We are going to lower the bumper to start at 1 inch
We are going to move as much weight to the extensions as we can
We are only going to use the four main wheels to drive, once in our defensive area we will move between the two zones to bog entrance and egress from the opposing team scoring zone on the safe side of the caution line.
We are going to create some code to keep the robot on the safe side of the caution line using one of our light sensors
We are going to use steel plates as opposed to sand to ballast our extensions
We are going to use 8 high traction wheels to maximize friction and moment of inertia during defensive game play
We are going to keep our pseudo bumpers the same color as our real bumpers and put the team number on them as well
We are going to make a very structurally sturdy bot to be able to withstand high kinetic energy impacts
Let me know if the students missed any changes.
crazy engineer
www.jjbiel-goebel.com
helping team 1389
http://team1389.com/
  #39   Spotlight this post!
Unread 18-01-2011, 21:47
staplemonx's Avatar
The Idea Guy
AKA: JJ Biel-Goebel
--Ryan
One of the kids asked about putting a leaf blower on the top of the robot to work against that. Not sure if that is legal plus it seems like a good bit of work so i told them to keep it in their back pocket if we have time at the end we can work on it.
crazy engineer
helping team 1389
  #40   Spotlight this post!
Unread 18-01-2011, 22:01
HannahF's Avatar
HannahF HannahF is offline
Laced in a Legacy
FRC #0433 (The Firebirds)
HannahF has a brilliant futureHannahF has a brilliant futureHannahF has a brilliant futureHannahF has a brilliant futureHannahF has a brilliant futureHannahF has a brilliant futureHannahF has a brilliant futureHannahF has a brilliant futureHannahF has a brilliant futureHannahF has a brilliant futureHannahF has a brilliant future
hmmm I don't know about a leaf blower, but a gaint net sure would be cool! It could be attached to the "wings" and fling out at the beginning of teleop almost like a colapsible volley ball net that would make passing or throwing the tubes over you very difficult for your opponents
I love this design! I am so excited that the Rambots are off to such a great start in this season and in FIRST
~Hannah
FIRST is like family and now my Family does FIRST!!
[2008-2011] Firebirds 433 Student, Head of Programming, Vice President
[2013-2015] Bambiebotz 4637 College Mentor
[2015-Present] Firebirds 433 Mentor, Strategy and Design
  #41   Spotlight this post!
Unread 18-01-2011, 22:24
jharold12's Avatar
jharold12 jharold12 is offline
Aquisitions Subteam Member
AKA: Jim Harold
FRC #1126 (SparX)
Team Role: Student
jharold12 is an unknown quantity at this point
The only problem there would be the fact that you cannot have control of more than one game piece at any given time. The net would probably collect multiple game pieces, and it would be pretty hard to release them when they are caught. Nice idea, though!
  #42   Spotlight this post!
Unread 18-01-2011, 22:44
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
WOAH! I just noticed the team name .
  #43   Spotlight this post!
Unread 18-01-2011, 22:46
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
27 X 54 ft field.
27x12= 324in
robot length= 82 in
58/12= 4.8333 ft
If only you could have 2 robots with this strategy and one pure scoring bot. You could effectively build a wall without a need to maneuver back and forth. The odds would be against an alliance being able to get both though unless one of them actually got to pick and was ranked first.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
  #44   Spotlight this post!
Unread 18-01-2011, 23:16
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
--Ryan
Quite honestly, forcing an alliance to perform this strategy would be an excellent defense! From past games (07 and 08, particularly) 50% of robots spend a large portion of their time acquiring game pieces... if you can force an alliance to have to acquire each game piece twice, you'd be doing a lot! This would be less effective the better your competition is...
The strategy that 3553 is proposing is by no means a game-breaking strategy... it's not like you're putting an infinitely tall stone wall in front of their goals! This is a very strong deterrent that will likely reduce the opponents score more than an average offensive robot would increase your own alliances' score. Simply put, the right robot can play effective - but not bullet-proof - defense with this strategy.
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
  #45   Spotlight this post!
Unread 18-01-2011, 23:27
HannahF's Avatar
Laced in a Legacy
thanks I didn't even think about it like that Also after spending more time thinking about the net i realized that a robot with a claw could easily get tangled/ destroy a net... oh well, I still really like the dragonfly design though
~Hannah
