Go to Post While money can create fancy-looking robots, it does not always create game-winning ideas. - Karibou [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 18-01-2011, 20:05
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
CAN Example
Can someone please post a working code example for CAN, it can be Java or C++. We're having some trouble.
Thanks,
James from Team 3309
Unread 18-01-2011, 22:28
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
Re: CAN Example
There are some examples in the CANJaguar project on FIRST Forge. Specifically we were looking at this file to get started. The CANJaguar project is deprecated since the library is now part of WPILib but it still gives a good example with a similar API.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Unread 18-01-2011, 23:54
imac256 imac256 is offline
AKA: Ian McInerney
FRC #2022 (Titan Robotics)
imac256 is a glorious beacon of lightimac256 is a glorious beacon of lightimac256 is a glorious beacon of lightimac256 is a glorious beacon of lightimac256 is a glorious beacon of light
Re: CAN Example
My team used CAN last year, so our C++ code from 2010 contains examples. That code can be here.
I have attached excerpts of our code from last year which deal specifically with using the CAN bus. At the end of the file there is also an excerpt from the 2011 C++ RobotDrive class which shows how to use synchronization. (found in CANExamples.txt)
Synchronization uses an 8-bit mask which is sent to the motors when the output speed is set, and then a later function is used to send a packet to the Jaguars telling them to execute the previously sent command. A enumerated list of the synchronization groups can be found in the other attached file (synchronization.txt).
If you have any questions about any of the code examples I gave feel free to ask me.
Hope this helps.
File Type: txt synchronization.txt (547 Bytes, 17 views)
- Ian McInerney
Alumni & Mentor, Team 2022 Titan Robotics
Junior, Iowa State University majoring in Electrical Engineering
