Go to Post When you come down to it, FIRST is about people inspiring other people; STEM and the robots are just the subject matter. - RyanCahoon [more]
Unread 18-01-2011, 22:38
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Playstation 3 Controller in LabView
The Playstation 3 Controller is not supported under Windows without installing drivers so it will not work with the Driver Station app.
Having said that there is a very similar controller that will. A Logitech Dual Action gamepad will run you about $20, is very similar to a PS3 controller and will definitely work with the Driver Station (we used one the past two years as our "operator" controller).
The Dual Action does not have the gyro/accelerometer feature, the buttons are not pressure sensitive like a Ps3 controller and there is no force feedback.
Unread 19-01-2011, 00:07
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
I believe our team is using the F310 model
Two years ago we tried using the wired 360 controllers and didn't like them due to there being a large deadband about the analog sticks center.
Our drive team has been practicing with the F310s this year, they've been approachable for the students and seem to be well received. They certainly seem to have an easier time controlling tank drive on this type controller as opposed to two joysticks.
Unread 19-01-2011, 12:36
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
As for PS3 Controllers I do not know if they sell plug and play PS3 controllers so I don't know if it would work. But for an Xbox 360 controller you can definitely do that (if you bought the PC Version). You wouldn't even need special code just open joystick USB 1-4.
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
Unread 19-01-2011, 12:39
If the device is considered an HID joystick or gamepad, it can be used with the DS. To do this, it may need USB adapters, custom drivers, etc.
Greg McKaskle
Unread 31-03-2012, 10:25
IGM IGM is offline
Student Software Lead
AKA: Eric Rock
FRC #1126 (SparX)
IGM is on a distinguished road
Old thread is old, but the MotionJoy program installs custom drivers that allow the PS3 controller to be read by the DS.
Team 1126 managed to get this running successfully using USB-2 connection.
"Nothing is true. Everything is permitted." - Altair, Assassins' Creed
"I'm trying to free your mind." - Morpheus, The Matrix
