Go to Post Seeing a bunch of teams from Indiana and probably Michagin competing at the same time.... If I wanted to see that, I'd just go to the Championship in Atlanta. :yikes: - Barry Bonzack [more]
Unread 18-01-2011, 16:26
mathgeek01 mathgeek01 is offline
C++ Ninja in Training
FRC #3397 (Robolions)
mathgeek01 is an unknown quantity at this point
Question Connecting the KOP Line Sensor
Hi,
I'm working on getting the KOP Line Sensors working on my team's robot. It seems to me, based on what I've seen on the forum, that it should be connected to the Digital Sidecar in the Digital I/O section. I understand which wires should go where. My question is, what sort of adapter can I use to connect the wires of the sensor to the pins of the sidecar?
Unread 18-01-2011, 16:35
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Connecting the KOP Line Sensor
You really have two choices:
1. Cut a standard PWM cable in half, and solder the signal wire you wish to use to the white lead on the PWM cable. Plug into the digital side car as you normally would.
2. Terminate the signal wire into a 0.100" pitch molex connector, just make sure you get it in the correct position for connection on the DSC. We've used these before, and they work amazingly well - it's essentially like making your own PWM cables. We've also used several others in the product series on the robot before - the single row, 5 circuit for encoder input into the Jaguars, the dual row, 4 circuit for limit switch input into the Jaguars, etc.
Unread 18-01-2011, 16:36
Cut a PWM cable in half and splice the signal wire from the sensor (either black or white) to the signal wire going to the Digital Sidecar (white).
If you're not comfortable splicing wires, use the terminal strip from the Kit of Parts. Screw the incoming wire to one side, and the outgoing wire to the other side.
Make sure you connect power to the sensor properly. The power wire (brown) goes to the red side of a 20 amp circuit from the Power Distribution board, and the common wire (blue) goes to the associated black side. Again, splice appropriately-sized power wires to the sensor wires (or use the terminal strip), because the large Wago connectors aren't designed for the small gauge wire of the sensor.
Unread 18-01-2011, 19:25
Bob Steele's Avatar
AKA: Bob Steele
Are we going to have any problems because the sensor out put is at 12 Volts? These are 12 Volt input and 12 Volt output..
Should we reduce voltage on the line back into the Digital Sidecar? Or is it ok because the amperage is so low?
thanks
Unread 18-01-2011, 22:38
tagayoff's Avatar
tagayoff tagayoff is offline
FRC #3512
tagayoff is a jewel in the roughtagayoff is a jewel in the roughtagayoff is a jewel in the roughtagayoff is a jewel in the rough
Smile Re: Connecting the KOP Line Sensor
thanks
No need to reduce the voltage. See this exhaustive discussion.
http://www.chiefdelphi.com/forums/sh...ad.php?t=88548
Unread 18-01-2011, 22:51
The signal lines are not 12v. They are just simple switches. Connecting them to the 5v signal line on a DIO puts 5v through them if the switch is closed, nothing of course if the switch is open.
12v only powers the sensor itself. It isn't connected to the signal line at all.
Unread 20-01-2011, 15:27
DSST\neal.ian DSST\neal.ian is offline
AAHHH!! WHERE'D ALL THE TIME GO?!?!
AKA: Ian Neal
FRC #2240 (Brute Force)
DSST\neal.ian has a spectacular aura aboutDSST\neal.ian has a spectacular aura aboutDSST\neal.ian has a spectacular aura about
Send a message via AIM to DSST\neal.ian Send a message via MSN to DSST\neal.ian Send a message via Yahoo to DSST\neal.ian
Exclamation Line sensor & BSL HELP?!?!
After reading all this, I'm still having a problem with even turning the sensors on. I have the white connected to the white on a PWM, black not connected, blue to black on PWM, and brown to red. Two sensors are wired this way, plugged into DIO1 and DIO2 (I even triple-checked the orientation!). The power is plugged into the sidecar and everything. For reasons unbeknown to me, after I did this, the signal light stopped working (I tried a different DSC, too, with no positive results) and the sensors don't turn on. I'm getting a voltage in the power plug (checked w/ a volt meter) and the motors still run, but no sensors, and, now, no signal light. Help?!?!
-2010 Finalists! CO Regional 2010
2240 BRUTE FORCE!!!!!!!
Our site: http://robotics.scienceandtech.org
Unread 20-01-2011, 16:01
Re: Line sensor & BSL HELP?!?!
Originally Posted by DSST\neal.ian View Post
After reading all this, I'm still having a problem with even turning the sensors on. I have the white connected to...
Your white signal connection is okay, but that's about it. It is likely that you are loading the 5 volt output of the Digital Sidecar hard enough to shut it down. Disconnect everything and start over.
Brown is the power input. It goes to a red Wago connector 12 volt output from the Power Distribution, with a 20 A breaker.
Blue is the common. It goes to the black Wago connector next to the one providing power.
White is signal. Black is another signal. Either one goes to the signal input on one of the Digital Sidecar DIO connectors. On a standard PWM cable, that is a white wire. There is no connection to the power (red) or common (black) of the DIO connector.
Note that there is only one wire connected from the sensor to the Digital Sidecar. Power comes from the big Power Distribution block.
Unread 20-01-2011, 16:18
AKA: Ian Neal
OH!!!! Duh. Thank you!
