Go to Post So, FIRST is turning into the For the Inspiration of Science and Trains? That makes sense... Not a whole lot of re-branding will be needed.... - dqmot17 [more]
Unread 18-01-2011, 23:02
Jimmy the Kidd's Avatar
Jimmy the Kidd Jimmy the Kidd is offline
Programmer, Scouter, Tactician, etc
FRC #0364 (Team Fusion)
Team Role: Tactician
Jimmy the Kidd is an unknown quantity at this point
Re: Mini-bot Hinges
Originally Posted by BJT View Post
Update#3 seems to rule out hinges on the minibot. you could make one, but purchasing a pre-made hinge, regardless of material, seems to be out. right?
A couple of the posters here and I seem to have the same opinion. You should be able to only MAKE hinges. Buying them is against the rules.
