#16
Re: Mini-bot Hinges
I think many door hinges are steel, though. Steel isn't allowed... so you'd have to find aluminum ones. Or the polycarb ones listed earlier. Assuming, of course, that the GDC allows non-team-manufactured hardware that isn't otherwise legal. |
#17
Re: Mini-bot Hinges
What I was trying to say is that Team Update 3 does not require that teams are the group that fabricated said materials - if the items are made from things exclusively from that list they are legal.
#18
Re: Mini-bot Hinges
There's another way to look at this: Where, on the list of allowed materials, do you find COTS parts? Parts A-E (Tetrix/FTC), I, K-N, P, S, U, X, Y, AA, BB. All the other parts are going to require some modification. Rope, wire, tape, velcro, PVC, and loctite are all going to need to be removed from their containers or cut to length or otherwise worked with. Aluminum and polycarb will need to be cut and shaped and otherwise moved from raw material (the COTS form) to fabricated item. I don't necessarily like it either, but that's the way the rules are currently written and interpreted. If that's not the way they should be written, then the GDC needs to change that--and I happen not to have access to ask that sort of question on Q&A. |
#19
Re: Mini-bot Hinges
And for what it's worth (standard disclaimer that even posts by Dave Lavery on CD are no substitute for the Q&A here): If the Manual was worded differently I don't see why he'd make that post... |
#20
Re: Mini-bot Hinges
i believe that the rule says polycarbonate and not polycarbonate parts... This is one to ask Q and A I will be very surprised if they say that a pre-made polycarbonate hinge is the same as "polycarbonate" As an inspector unless I had a definite Q and A response that indicated that this was ok I would not allow that pre-made hinge. And by the way... VEX metal isn't made of aluminum it is made of steel. (You can get a very expensive set of VEX parts made in aluminum but the pieces you get in the kit and that 99% of all teams use are made of steel. Dave's statement can be interpreted several ways... you decide how to do it.. Yes VEX metal is still steel...it was made of it... But is steel the same as vex metal..??? Last edited by Bob Steele : 19-01-2011 at 00:10. |
#21
Re: Mini-bot Hinges
Don't read into the rules what's not there.
"Polycarbonate" with no other strings attached is listed as a "permitted material" in rule R92F. Where (exact rule #) are these imaginary restrictions on what constitutes legal polycarbonate and illegal polycarbonate coming from? |
#22
Re: Mini-bot Hinges
Art, <R92> simply states that "The following items are the only permitted materials for use on the MINIBOTS:" [list]
It then lists a long line of various COTS-type items and what sure looks like raw materials. While it nowhere says "COTS" or "Fabricated item", there are strong conclusions that can be drawn from what the terminology says. For example, if the list had said "steel", would you think that screws, nuts, and bolts were legal? I know I wouldn't! But screws, nuts, and bolts are called out in another item on the list, so they are legal. As it stands right now, both sides have the right answer, because clarification has not come. I'd much rather inspections not turn into lawyering to the effect of, "But it's made of X..." "But it's not on the list..." Somebody needs to ask Q&A. Something simple, like, "I can buy a COTS item that is entirely made of an allowed material from R92. This item is not listed elsewhere in R92. Is it legal?" would probably work quite well for getting a GDC response one way or the other. |
#23
Re: Mini-bot Hinges
So basically what you're saying is you're making up "strong conclusions" based on things you admit aren't said in the rules at all. Please for the sake of less-informed teams skimming over these threads do not post things you don't know to be true.
#24
Re: Mini-bot Hinges
Reading between the lines are for philosophical or political discussions. FRC rules are black and white. |
#25
Re: Mini-bot Hinges
Now to find some 7068 aluminum bearings
#26
Re: Mini-bot Hinges
Except that this one can be read in two ways, black and white. Like I said, I wouldn't see that "steel" included "steel screws, nuts, and bolts that I buy at a hardware store". I'd see "steel" and think, "steel plate, tube, bar that I can form stuff with". You're seeing "steel" and thinking "steel, plate, tube, bar, screw, nut, bolt, and other hardware". Two different points of view, one single word. Because it is quite possible to do that, I propose that we let this topic lie until somebody can ask the Q&A. I can't do that asking, BTW--no account and no team. Q&A is the only official source for making black or white into black and white. |
#27
Re: Mini-bot Hinges
To anyone that might stumble upon this thread: Don't use the hinges until it was asked in Q&A. |
#28
Re: Mini-bot Hinges
"Polycarbonate" is a polymer. It is not a specific formation of that polymer in any particular sheet - all of which would be "COTS" anyway. Last edited by Chris is me : 19-01-2011 at 01:41. Reason: last part would have been bad |
#29
Re: Mini-bot Hinges
Is the COTS polycarbonate hinge legal?
Ask schrodinger's cat. Until the Q&A rules on it, the hinge is both legal and illegal. According to the letter of the rule, as laid out, right now... I believe they are legal. At the very least, they are not specifically illegal. But what you are seeing here is a number of FRC veterans reading that rule and putting it in to the context of previous GDC rulings over the past several years, and making a reasonable interpretation as to the intent of the rule.... and I believe they are correct. I believe the hinge, in the context of the rules and previous GDC decisions, is illegal. So until someone opens the box, by asking the Q&A or undergoing tech inspection, the hinge, like the cat, is both alive and dead. Jason P.S. I don't want to imply that your robot is "legal" just because you've passed tech inspection. It is quite possible that you passed tech due to an oversight by your inspector that will require adjustment at some future point of time. |
#30
Re: Mini-bot Hinges
You could use the tetrix servo-controlled hinges set up with two servos to increase power. You still may need latching mechanisms both to hold the arm(s) in place during robot movement and after minibot deployment.
