Go to Post You can never have enough teamwork. - Koko Ed [more]
Unread 18-01-2011, 23:27
Re: Mini-bot Hinges
Originally Posted by Chris is me View Post
But the hinges are made exclusively of materials found on the list of allowed parts. Why is it suddenly required that you hand make them if they are literally just shaped versions of what is allowed?
Ask the GDC.
I think many door hinges are steel, though. Steel isn't allowed... so you'd have to find aluminum ones. Or the polycarb ones listed earlier. Assuming, of course, that the GDC allows non-team-manufactured hardware that isn't otherwise legal.
Unread 18-01-2011, 23:29
Chris is me's Avatar
AKA: Pinecone
Re: Mini-bot Hinges
Ask the GDC.
What I was trying to say is that Team Update 3 does not require that teams are the group that fabricated said materials - if the items are made from things exclusively from that list they are legal.
Unread 18-01-2011, 23:53
Re: Mini-bot Hinges
The GDC has not said that teams can go out and buy their X Minibot material pre-formed into final form. They have said that the team can machine said materials. If I were to go out and buy VEX metal (aluminum), I might have a hard time passing inspection as the rules stand. But I can go out and buy aluminum and machine it into VEX metal, and I'd get some funny looks but would probably pass inspection.
There's another way to look at this: Where, on the list of allowed materials, do you find COTS parts? Parts A-E (Tetrix/FTC), I, K-N, P, S, U, X, Y, AA, BB. All the other parts are going to require some modification. Rope, wire, tape, velcro, PVC, and loctite are all going to need to be removed from their containers or cut to length or otherwise worked with. Aluminum and polycarb will need to be cut and shaped and otherwise moved from raw material (the COTS form) to fabricated item.
I don't necessarily like it either, but that's the way the rules are currently written and interpreted. If that's not the way they should be written, then the GDC needs to change that--and I happen not to have access to ask that sort of question on Q&A.
Unread 19-01-2011, 00:01
AKA: Pinecone
Re: Mini-bot Hinges
To put it frankly - I think you're making that restriction up. It's said nowhere in any Manual, you're just deriving it.
And for what it's worth (standard disclaimer that even posts by Dave Lavery on CD are no substitute for the Q&A here):
Originally Posted by dlavery View Post
Isn't [Vex metal] still [aluminium sheet]?
If the Manual was worded differently I don't see why he'd make that post...
Unread 19-01-2011, 00:03
Bob Steele's Avatar
AKA: Bob Steele
Re: Mini-bot Hinges
I think you are swimming in dangerous water if you think that when they say polycarbonate that means you can use anything made of that...
i believe that the rule says polycarbonate and not polycarbonate parts...
This is one to ask Q and A
I will be very surprised if they say that a pre-made polycarbonate hinge is the same as "polycarbonate"
As an inspector unless I had a definite Q and A response that indicated that this was ok I would not allow that pre-made hinge.
And by the way... VEX metal isn't made of aluminum it is made of steel.
(You can get a very expensive set of VEX parts made in aluminum but the pieces you get in the kit and that 99% of all teams use are made of steel.
Dave's statement can be interpreted several ways... you decide how to do it..
Yes VEX metal is still steel...it was made of it...
But is steel the same as vex metal..???
Unread 19-01-2011, 00:18
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: Mini-bot Hinges
Don't read into the rules what's not there.
"Polycarbonate" with no other strings attached is listed as a "permitted material" in rule R92F.
Where (exact rule #) are these imaginary restrictions on what constitutes legal polycarbonate and illegal polycarbonate coming from?
Art Dutra IV
世上无难事,只怕有心人.
Unread 19-01-2011, 00:31
Re: Mini-bot Hinges
Art, <R92> simply states that "The following items are the only permitted materials for use on the MINIBOTS:" [list]
It then lists a long line of various COTS-type items and what sure looks like raw materials. While it nowhere says "COTS" or "Fabricated item", there are strong conclusions that can be drawn from what the terminology says. For example, if the list had said "steel", would you think that screws, nuts, and bolts were legal? I know I wouldn't! But screws, nuts, and bolts are called out in another item on the list, so they are legal.
As it stands right now, both sides have the right answer, because clarification has not come. I'd much rather inspections not turn into lawyering to the effect of, "But it's made of X..." "But it's not on the list..." Somebody needs to ask Q&A. Something simple, like, "I can buy a COTS item that is entirely made of an allowed material from R92. This item is not listed elsewhere in R92. Is it legal?" would probably work quite well for getting a GDC response one way or the other.
Unread 19-01-2011, 00:54
AKA: Pinecone
Re: Mini-bot Hinges
So basically what you're saying is you're making up "strong conclusions" based on things you admit aren't said in the rules at all. Please for the sake of less-informed teams skimming over these threads do not post things you don't know to be true.
Unread 19-01-2011, 00:55
artdutra04's Avatar
Re: Mini-bot Hinges
If made of steel, yes.
Reading between the lines are for philosophical or political discussions. FRC rules are black and white.
Art Dutra IV
世上无难事,只怕有心人.
Unread 19-01-2011, 01:01
Aren_Hill's Avatar
Build Nifty Things
Re: Mini-bot Hinges
Now to find some 7068 aluminum bearings
A guy who likes robots.
Unread 19-01-2011, 01:06
Re: Mini-bot Hinges
Chris, do you know for sure that it is legal to use items that are COTS on the Minibot just because their material matches a legal material? If so, what rule? I'd be interested in knowing.
Except that this one can be read in two ways, black and white. Like I said, I wouldn't see that "steel" included "steel screws, nuts, and bolts that I buy at a hardware store". I'd see "steel" and think, "steel plate, tube, bar that I can form stuff with". You're seeing "steel" and thinking "steel, plate, tube, bar, screw, nut, bolt, and other hardware". Two different points of view, one single word. Because it is quite possible to do that, I propose that we let this topic lie until somebody can ask the Q&A. I can't do that asking, BTW--no account and no team. Q&A is the only official source for making black or white into black and white.
Unread 19-01-2011, 01:16
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Re: Mini-bot Hinges
Since you brought up less-informed teams, wouldn't we be better off suggesting something isn't allowed that is rather then the opposite. I'd much rather get to a regional and find out I could use an extra motor then have to figure out how to do without one I was planning on using. Also, I think you should take Eric at his word. He isn't just a random guy that happens to post on here. He's read every manual for as long as I can remember and knows people who do the inspections. If he can interpret that way(even if your right and he is falsely interpreting it) so can inspectors.
To anyone that might stumble upon this thread: Don't use the hinges until it was asked in Q&A.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 19-01-2011, 01:41
AKA: Pinecone
Re: Mini-bot Hinges
It'd be the rule that says parts that match what the rules say can be used on the robot. That's... most of them.
"Polycarbonate" is a polymer. It is not a specific formation of that polymer in any particular sheet - all of which would be "COTS" anyway.
Last edited by Chris is me : 19-01-2011 at 01:41. Reason: last part would have been bad
Unread 19-01-2011, 02:05
dtengineering's Avatar
AKA: Jason Brett
Re: Mini-bot Hinges
Is the COTS polycarbonate hinge legal?
Ask schrodinger's cat. Until the Q&A rules on it, the hinge is both legal and illegal.
According to the letter of the rule, as laid out, right now... I believe they are legal. At the very least, they are not specifically illegal.
But what you are seeing here is a number of FRC veterans reading that rule and putting it in to the context of previous GDC rulings over the past several years, and making a reasonable interpretation as to the intent of the rule.... and I believe they are correct. I believe the hinge, in the context of the rules and previous GDC decisions, is illegal.
So until someone opens the box, by asking the Q&A or undergoing tech inspection, the hinge, like the cat, is both alive and dead.
Jason
P.S. I don't want to imply that your robot is "legal" just because you've passed tech inspection. It is quite possible that you passed tech due to an oversight by your inspector that will require adjustment at some future point of time.
Unread 19-01-2011, 09:03
wexlerd1 wexlerd1 is offline
FRC #2547
wexlerd1 is an unknown quantity at this point
Re: Mini-bot Hinges
You could use the tetrix servo-controlled hinges set up with two servos to increase power. You still may need latching mechanisms both to hold the arm(s) in place during robot movement and after minibot deployment.
