Go to Post Beware of the following: boredom intelligence = ??? <- could be anything... - JBotAlan [more]
Unread 12-01-2011, 19:45
Pmaxm00 Pmaxm00 is offline
Lead Programmer
FRC #2974 (Team WALT)
Pmaxm00 has a spectacular aura aboutPmaxm00 has a spectacular aura about
Lightbulb 2011 WPILIBJ Java Documentation
I got bored today so I tried finding Java Documentation for this years code packages, and I couldn't find anything... SOOOOOOOO I ended up generating it on my own and uploading for public use. Check it out at http://javadoc.waltonrobotics.org/.
Impossibility? I accept your challenge.
Unread 12-01-2011, 20:04
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: 2011 WPILIBJ Java Documentation
Gracias por la esa. Anyways what is the difference from last year's? Is the back end more efficient than last year's was or is it just to be compatible with the Classmates?
Unread 12-01-2011, 20:30
Lead Programmer
So far I have not found a difference in the code. Tomorrow I will probably check out to see what the differences are.
Unread 12-01-2011, 20:55
Alexander Meyer Alexander Meyer is offline
FRC #2358 (Bearbotics)
Alexander Meyer is on a distinguished road
The Javadocs are located in the sunspotfrcsdk folder, which on Windows is in C:\Documents and Settings\{user}, and on Linux is in the home folder.
Unread 13-01-2011, 01:08
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
They changed it in so many subtle ways this year. 10 minutes into the coding, I realized that they removed the "sensitivity" parameter of the RobotDrive class. I read and re-read the manual but didn't find anything. Also, there's a new class called the SmartDashboard class (in changelog), but I couldn't find the documentation for it. Confused me until I noticed that the javadocs said "2010" on it.
Unread 13-01-2011, 01:28
Programming
By the way, your web version does not contain all the documents.
I uploaded a more complete version onto Google projects.
http://frc-2011-javadocs.googlecode.com/files/doc.zip
Unread 14-01-2011, 13:32
Lead Programmer
Thanks Patrick, I uploaded that to fix the faults I had.
Unread 15-01-2011, 03:01
Programming
No problem. We're still missing parts of it, like the squawk device libraries. I figured out how to generate javadocs for external library last night but now I can't remember.
EDIT: Nevermind, I found the javadocs already generated inside the Squawk SDK. How did I miss that?!
Anyway, here's the new link: http://frc-2011-javadocs.googlecode....avadoc2011.zip
Unread 16-01-2011, 18:50
Ryan O's Avatar
Ryan O Ryan O is offline
FRC Eclipse Plug-in Developer
no team (FRC Eclipse)
Ryan O is an unknown quantity at this point
Send a message via AIM to Ryan O
Also, javadocs not being accessible is the type of thing we'd love to see entered into the WPILib Tracker for consideration as a shortcoming to fix - the javadocs are linked into the FRC Eclipse Plug-in Help Contents (though this thread has made me double check what is linked and realize that they are slightly behind update wise, which will be fixed in the next stable release)
Anything else along these lines which you think needs fixing, feel free to put on the Tracker at http://firstforge.wpi.edu/sf/tracker...wpilib/tracker
CRUD Name: Windows
Alumni to Team: 350
Unread 17-01-2011, 22:41
LukeS LukeS is offline
4272 mentor, 1024 alumnus
AKA: Luke Shumaker
FRC #4272
LukeS is an unknown quantity at this point
I'd done a diff of a backup of the pre-update code with the new code. I no longer have the diff or the original code, but here is a summary of what I found.
A lot of subtle stuff. A few protocols were changed in ways I don't fully understand. A few places it was adjusted how data was represented (signedness, making sure only so many bits made it onto the network. A lot of stuff was rearranged to make the whole thing more OO; everything's better about extending/implementing the right stuff. There are more built-in drive modes. CANJaguar is now in the library, instead of a separate set of files. These are quite a bit different from the old CANJaguar files, internally; they seem to work about the same, though they have more methods.
Unread 19-01-2011, 00:22
Lead Programmer
Originally Posted by Patrick Chiang View Post
Okay, I am currently re-uploading it. How exactly do you generate api/javadoc for all of it? I found a way, but apparently it didn't get everything.
Unread 19-01-2011, 01:46
Programming
Heh. There's no need to upload it any more. I figured out later that it's already generated on your computer. Find the Doc folder in your sunspotsdk folder and it should already be there.
Unread 19-01-2011, 18:39
Lead Programmer
Ohhhhhh Okay. Eh, I'll still keep it uploaded and up to date just for the heck of it.
