Go to Post Isn't FIRST robotics the answer to life, the universe, and everything? - weberr [more]
Unread 19-01-2011, 02:15
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Why Windriver?
Why? I want to know why FIRST chose Windriver. Is it because of marketing deals? It's restricted by licensing agreements. Why can't aren't 3rd party IDEs like CodeBlocks officially supported? CodeBlocks is flexible; it supports lots of compilers from GCC to TurboC++. I don't see a problem having the specific compiler for the cRio to work with CodeBlocks. I believe that the Open Source softwares are better fit for FIRST's mission than a company that owns proprietary software. NetBeans is open source, which is good. One reason why my team is not using C++ is the fact that WindRiver is a pain. Same goes for LabView... I personally think this competition needs to step away from specific companies to a wide variety of companies. Like having an option for an ARM based processor instead of cRio, or an AVR based. Yes I know the issue of "standardization" and "safely communicating". They can go the extra mile to support other hardware. Its not that radical of an idea.
Edit: Also why not Linux in replacement for VxWorks?
Oh I will be releasing our source code online later in the season.
